Final word on TB Pulley for Skunk 2 Manifold on GSR
Old Sep 22, 2003 | 08:32 PM
BolivianDc2's Avatar
Default Final word on TB Pulley for Skunk 2 Manifold on GSR
Here is my situation, I have a skunk 2 manifold, I've tried using multiple TB pulleys and springs, which include:
-d16 TB pulley and spring
-1st gen b16 TB pulley and spring
the 1st gen pulley fits really bad, the d16 pulley fits perfect, but gets jammed because of the angle it hits the screw that stops it from closing.
What is the proper TB pulley and spring to use on the skunk 2 manifold, where did you anchor down the spring on the GSR TB? Did you modify the spring or the pulley in anyway?
Thanks alot
Old Sep 22, 2003 | 08:50 PM
Spike2's Avatar
Default Re: Final word on TB Pulley for Skunk 2 Manifold on GSR (Bolivianstrtwpn)
You will the the Type R throttle cable holder. It holds the cable onto the manifold as you can hopefully see in the attached pic.
You also need the Type R throttle cable.
And use the single cam throttle pulley, or anything other than GSR for that matter.
Let me know if you need any other help.
Old Sep 22, 2003 | 09:18 PM
Default Re: Final word on TB Pulley for Skunk 2 Manifold on GSR (Spike2)
the single cam TB pulley and the VTEC TB pulley are different, i'm asking which one should be used. Is there a specific year to go after?
Old Sep 22, 2003 | 09:54 PM
Spike2's Avatar
I am not aware of any difference between the years. Sorry I dont have a close up pic or anything but if you look closely the throttle body pulley will need to be positioned so the cable goes under it and then around to the top. Mine is from the stock d15 motor.
I will see if i can snap some more detailed pics.
Old Sep 23, 2003 | 01:29 AM
Mr.Integra's Avatar
i am using b16 tb pulley with gsr spring, works like a charm. You are right though, the b16 pulley is crap. I can't even WOT all the way because the pulley would not move anymore before the plate is fully opened.. still gotta fix that ****
Old Sep 23, 2003 | 05:29 AM
HOND PWR's Avatar
Default Re: Final word on TB Pulley for Skunk 2 Manifold on GSR (Mr.Integra)
I used a 93 civic cx pulley and spring. Put them on a 94 gsr throttle body, works just fine.
Old Sep 25, 2003 | 09:07 PM
darrinbrewer's Avatar
Default Re: Final word on TB Pulley for Skunk 2 Manifold on GSR (HOND PWR)
i used a h23 pulley..(not sure on year, but was same tb diameter at my gsr..gave the old TB to my ls equipped freind..it'll be a nice addidtion to any ls..
vacantskies88
Nov 12, 2014 11:39 AM
Kr4nG
Feb 21, 2008 05:22 PM
-Championship-
Dec 10, 2006 05:58 PM
SuicideSlide
Nov 16, 2004 09:57 PM
fowler!
Nov 7, 2002 11:36 AM
