i need solid info on putting an integra front end on a civic
i have a 92 hatch i just picked up and i want to put an integra front end on it.
where can i find in depth info on what i need to do?
thanks.
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy »</TD></TR><TR><TD CLASS="quote">try searching, it has been discussed a ton of times
all i found was some threads with some dead picture links and some JDM integra front ends. i need specific info which hasnt been laid out. will the integra core support weld directly onto the civic front end? where exactly do the fender have to be cut... etc
</TD></TR></TABLE>all i found was some threads with some dead picture links and some JDM integra front ends. i need specific info which hasnt been laid out. will the integra core support weld directly onto the civic front end? where exactly do the fender have to be cut... etc
thanks for the pics... but i already know what it would look like. im intersted in technical info. is that your car?
From: You can be my wingman anytime...., Las Vegas, US
Here's some solid info:
Don't do it.
...You have the right to do what you want, but I really don't like the conversion, the integra front is too sleek for any civic.
Don't do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay »</TD></TR><TR><TD CLASS="quote">Here's some solid info:
Don't do it.
...You have the right to do what you want, but I really don't like the conversion, the integra front is too sleek for any civic.</TD></TR></TABLE>
im not looking for opinions. thanks.
Don't do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 »</TD></TR><TR><TD CLASS="quote"> im intersted in technical info.</TD></TR></TABLE>
The core support is "supposed" to weld up, If it doesn't there is some minor cutting trimming to do. I did not use the core support on my car.
The fenders are going to be joined with a set of stock civic fenders. Cut them generally right down the middle above the wheel well. Your going to have to use some imagination on that one because keep in mind you have to get the two different contours of the fenders to line up, and try to avoid using a ton of bondo. You will be needing to weld them back up. The cut is not going to be perfectly straight to get them to line up. You can even cut them towards the back of the wheel opening and just cut off the contour that the stock civics use and use trhe wheel opening of the integra stuff, but they wont match the back quater panels.
That is the majority of the work, all the rest is simply bolting parts on.
The hood might need some trimming.
pm if you want clear explanations on this stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frosteg6 »</TD></TR><TR><TD CLASS="quote">heres some solid info, DONT DO IT
what gave you the impression that your opinion mattered??
</TD></TR></TABLE>what gave you the impression that your opinion mattered??
im not looking for opinions. thanks.</TD></TR></TABLE>
haha
haha
CTRwannaB
Feb 27, 2003 09:37 AM
