failed smog in cali, nox too high
Old Sep 22, 2003 | 07:04 PM
GSRacer1's Avatar
Default failed smog in cali, nox too high
what to do to fix nox levels
maybe somebody has gone through this
my numbers were
at 15 mph
hc 113 max allowed were 61
co 0.51 max " " 0.54
nox 2072 max allowed 467
how do I fix this
at 25mph
hc 29 max 45
co 0.49 max 0.53
nox 966 max 754
what could be causing this problem?
any suggestions to fix it
Old Sep 22, 2003 | 07:50 PM
Jolf's Avatar
Default Re: failed smog in cali, nox too high (GSRacer1)
Wish I knew, hopefully somebody here can help.
Back when I had my 4age it failed horribly so I took it too the dealership and showed them the slip and they pointed out a few things to do including a new cat and it passed no problem.
Old Sep 22, 2003 | 09:12 PM
SDturbogsr's Avatar
Default Re: failed smog in cali, nox too high (Jolf)
Replace the cat and try again. After that, maybe an air filter?
Old Sep 22, 2003 | 09:37 PM
Lord Helmet's Avatar
more info man!!! what's the mileage on your engine? done a major tune lately? correct ignition timing? been playing with the cam timing lately? we don't know how to help you if we don't know the setup of your engine if you don't tell us.
Old Sep 22, 2003 | 09:52 PM
JadeDM's Avatar
hey bro... i failed on the same ****!
i replaced my cat and mine worked but it could also be the main 02 sensor. If you need a working main 02 sensor, let me know i got one for sale
Old Sep 22, 2003 | 10:31 PM
Trac226's Avatar
Default Re: (JadeDM)
Yup, most likely your cat and/or O2 sensor...
http://www.Preciseautocare.com - working at a smog station
Old Sep 23, 2003 | 07:18 AM
GSRacer1's Avatar
can a high flow cat work or do i have to get a stock cat
Old Sep 23, 2003 | 09:21 AM
roadrunner's Avatar
If you have any mods, please list them and we can go from there...
Old Sep 23, 2003 | 09:30 AM
emr88's Avatar
Default Re: (roadrunner)
Is your car throwing any CEL codes?
Have you checked?
Sounds like your EGR system is not working correctly.
Also, Is your timing set to factory spec or is it advanced? Your timing settings could affect NoX.
Even if it is set to stock, you can back it down a few degrees (no more than 3 degrees from stock though) to help reduce NoX.
As others have stated, provide more info including mileage, mods, etc.
Old Sep 26, 2003 | 02:55 PM
GSRacer1's Avatar
Default Re: (emr88)
thank you, for the comments
Old Sep 26, 2003 | 05:05 PM
gsrclan's Avatar
If yours is a 96/97 integra there is a emission warranty extension allows you to get it fixed for free.
Old Sep 27, 2003 | 08:05 AM
ee-gsr's Avatar
Default Re: (GSRacer1)
yeah. please list any mods. i'm interested in knowing more about parts that may cause me to fail smog in the future. thx
Old Sep 28, 2003 | 01:17 PM
player2z's Avatar
i know someone who can really help u he's my mechanic and good friend. email him at knmoua@aol.com his name is vinnie.... he can help
Old Sep 30, 2003 | 04:38 PM
GSRacer1's Avatar
OK, I changed the cat with a new carsound cat and put in some of that denaturized alcohol, put the timing back 2 degrees, got new plugs
and
you know what, I hate california's smog laws
I passed the nox part with flying colors but
hc and co2 levels went sky high
new numbers are
15mph test
GAS- MAX - MEASURED
HC - 61 - 170
CO - 0.54 - 2.44
NO - 467 - 43
25MPH TEST
HC - 45 134
CO - .53 1.85
NO - 754 32
PLEASE HELP
can i figure this out with out breaking bank
Old Sep 30, 2003 | 06:01 PM
GSRacer1's Avatar
anyone else have any ideas
Old Sep 30, 2003 | 09:47 PM
player2z's Avatar
hey this is billy, u sent me a message, but i cant respond to you!! but u can call me on my cell phone and i can try to help u. (916) 519-3102. Vinnie's from chico, ca. thanks
hatchinprogress
Aug 9, 2013 12:20 AM
jaybee1
May 18, 2013 08:21 AM
thewrai6th
Feb 11, 2013 01:36 PM
civicstar
Aug 25, 2007 07:05 AM
Splangtastic
Jun 19, 2003 01:30 PM
