Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
bigger brake master cylinder question
Old Sep 22, 2003 | 04:46 PM
555R's Avatar
Default bigger brake master cylinder question
if one was to upgrade to a bigger master cylinder from another company like willwood or another brake company
what is involved in the conversion
I need to know asap
thanks
Old Sep 22, 2003 | 06:12 PM
MightyMouseTech's Avatar
Default Re: bigger brake master cylinder question (555R)
They usually don't bolt on to your stock components. You will have to purchase a new brake pedal assembly that will accept the master. Going this route usually means installing dual cylinders with one channel for the front and another for the rear. (with appropriate sizes for brake balancing) Which means a replumbing of the brake lines (get rid of that diagonal system) and tossing the brake booster. And when you toss the booster, you will probably go with smaller than stock cylinders anyways, unless your right leg looks like the Terminators. The cylinders on my Civic are 2 sizes smaller than stock. I don't think this is all what you had in mind i bet.
Old Sep 22, 2003 | 08:14 PM
555R's Avatar
Default Re: bigger brake master cylinder question (MightyMouseTech)
nope not what i had in mind
i have bigger brakes front and rear
but the MC went bad after sitting for 6 months
Old Sep 22, 2003 | 11:25 PM
Bill Hook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 555R &raquo;</TD></TR><TR><TD CLASS="quote">if one was to upgrade to a bigger master cylinder from another company like willwood or another brake company
I need to know asap
thanks</TD></TR></TABLE>
BBKs should have the same piston volume as OEM calipers, if correctly designed. Any add'l brake torque should be a factor of leverage, if at all (a la StopTech).
Old Sep 23, 2003 | 03:12 AM
.RJ's Avatar
.RJ
Default Re: bigger brake master cylinder question (Bill Hook)
Yep, check out the link in the FAQ regarding big brake kits.
Old Sep 23, 2003 | 06:06 PM
555R's Avatar
Default Re: bigger brake master cylinder question (.RJ)
well i dont know now
i have issues
pedal still goes almost to the floor
I swapped in a new BMC and new pads
next will be rotors and then rebleed it all over again for the millionth time
and 6 bottles of wilwood 570
i checked vacuum on the booster and there is good vacuum
im getting pissed
Old Sep 23, 2003 | 06:13 PM
Bill Hook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 555R &raquo;</TD></TR><TR><TD CLASS="quote">well i dont know now
i have issues
im getting pissed</TD></TR></TABLE>
Sure the original MC is any good?
Oh, if you do have bigger brakes, then tell us what you did. You might just need a 1" MC from a GSR or something similar.
Old Sep 23, 2003 | 06:29 PM
555R's Avatar
i swapped in a new master cylinder BMC...
ribal_gh
11
Apr 30, 2013 04:24 AM
Markb16a
13
Apr 13, 2010 11:25 AM
VTECth1s
Jun 9, 2006 06:21 PM
blulude92
May 26, 2006 10:03 PM
Eggman
Oct 6, 2002 09:32 AM
