How does that trick w/ the ATF to clean carbon deposits work?
Old Aug 23, 2001 | 08:14 PM
clockworks's Avatar
Default How does that trick w/ the ATF to clean carbon deposits work?
I was told to just unplug a vacuum line off of the manifold and let it suck up a little fluid. How much should I have it suck up? Does it work well?
TIA,
Greg
Old Aug 23, 2001 | 08:28 PM
LostGsr's Avatar
Default Re: How does that trick w/ the ATF to clean carbon deposits work? (clockworks)
Also does this procedure cause any harm to the CAT? I heard there will be clouds coming out of the exhaust.
Old Aug 25, 2001 | 08:34 AM
earl's Avatar
Default Re: How does that trick w/ the ATF to clean carbon deposits work? (LostGsr)
It will smoke like a mf. Chemicals in tranny fluid will eat at the deposits. Make sure engine is WELL warmed up before doing this procedure. Shouldn't hurt a decent cat. I would use perhaps a half pint or less of fluid. Be sure to aim your exhaust at your neighbor's flower garden. They will thank you in many ways.
Old Aug 25, 2001 | 09:24 AM
TurboType-R's Avatar
New User
Default Re: How does that trick w/ the ATF to clean carbon deposits work? (earl)
if you want to clean carbon depostists, you can pour SMALL amounts of water into the throttle body, and that will clean it out.
Old Aug 26, 2001 | 02:42 AM
X2BOARD's Avatar
Default Re: How does that trick w/ the ATF to clean carbon deposits work? (TurboType-R)
Pour water into the T/B ??? Ack ACk ACK !!! maybe mist it in ..... Just get a CAI and drive in the rain HA HA HA.....j/k
I don't know about the cleaning of the deposits, but it's safe for the cat, just don't do it on a daily basis.....
ATF in the intake manifold makes for a hell of a smoke show.... I have seen a company over here that installs a system for a smoke screen in your car..... smash the pedal and ATF it...... FOOM.... you're fumigating the whole road..!!!!
hix1681
Nov 6, 2008 06:36 AM
jDm_eDm
Aug 19, 2006 02:37 PM
ruffyruff
Feb 27, 2006 06:42 AM
dayaftertomorrow
Apr 13, 2005 06:35 PM
StyleTEG
Feb 20, 2002 05:06 AM
