Fuel system upgrades f22b1
Old Sep 22, 2003 | 02:59 PM
veryslowaccord's Avatar
Default Fuel system upgrades f22b1
My long term plan for my car is F22b1 turbo. But money is short, so i can't turbo it right now, i figured i can start getting my car ready for the turbo. I was thinking i would upgrade the fuel system. Feul rail, pump, injectors, ignition, and an VTEC- AFC, and possibly intake minfold. im going to hold of on intake and header because they would get kicked in the turbo set up anyways. Would i make any gains from a fuel system upgrade, afc (tuned of cours), and intake manifold?
Old Sep 22, 2003 | 04:48 PM
accordexchange's Avatar
Default Re: Fuel system upgrades f22b1 (veryslowaccord)
i don't see the point in getting all those fuel upgrades before you get the turbo-you're probably going to run really rich... unless you do the vafc hack for a n/a setup but after the dyno time and all, i don't think it's worth it for the gains... just save your money and buy everything at once or buy the shiet now but don't put it on until you get the turbo...
Old Sep 23, 2003 | 11:35 AM
So i would just be wasteing gas for no power gains?
What can i do now,in preparation for a turbo that would still add power on an N/A setup
Old Sep 23, 2003 | 02:45 PM
Stew Pidasso's Avatar
Default Re: (veryslowaccord)
You wouldn't gain any hp. You need to add more air (forced induction) if you're going to add more fuel.
Old Sep 23, 2003 | 06:10 PM
Okley_01's Avatar
Default Re: (Stew Pidasso)
yup, i agree. not worth it. just keep saving. remember, good things come to those who wait.
Old Sep 23, 2003 | 06:34 PM
ArchAngel Sabastian's Avatar
New User
for the low budget all you need is some injectors, a safc/vafc, and boost timing master/ or alternate way to retard the timing when boosting, you could get a programable ECU tuned to do your timing/fuel changes both and negate the need for vafc/timing master but most of you dont have the means for this.
Old Sep 23, 2003 | 06:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veryslowaccord &raquo;</TD></TR><TR><TD CLASS="quote">So i would just be wasteing gas for no power gains?
What can i do now,in preparation for a turbo that would still add power on an N/A setup</TD></TR></TABLE>
there's a couple of things that you can do to prepare for turbo but it doesn't mean you'll gain power for your current n/a setup... a compression and leak down test would be good for starters... you could reinforce your motor with stronger internals... you could also upgrade your tranny too... besides that, look for deals on turbo parts and don't put them on until you have everything... if you don't have the money or can't be patient, then just keep on dreaming...
Old Sep 24, 2003 | 03:36 AM
boonacka's Avatar
Default Re: (accordexchange)
upgrade your clutch and get a lightened or lighten your flywheel. make sure your motor is in tip-top shape before you put the turbo on or else your gonna have a boat load of problems to hunt down while tuning. patience is really the key when going turbo... (still learning).. because its alot more work and time than you think..
Old Sep 24, 2003 | 01:35 PM
twkdCD595's Avatar
Default Re: (boonacka)
you could buy a afc, a catback exhaust 2.5 (60mm) inch or bigger for sure, modify the factory air box, and some other little things.
save your fun tickets, ramen is your friend.
Old Sep 24, 2003 | 05:10 PM
Default Re: (twkdCD595)
I've got a 2.25 inch (world sport) exhaust and don't plan on changing it. I wanna see if i can make torque
Old Sep 25, 2003 | 03:29 PM
do what you want smart guy-you don't need permission from any of us for you to modify your car...
jdmnic91
Aug 18, 2010 03:23 AM
integrawow
May 12, 2007 07:13 PM
Johnny_Rocket
Mar 3, 2005 10:18 PM
gliaw
Mar 13, 2003 11:29 AM
g2_boosted
Sep 28, 2002 06:32 PM
