90-93 Integra Radiator in 91 CRX... Clearance for A/C???
Old Sep 22, 2003 | 02:55 PM
VTECVillain's Avatar
Default 90-93 Integra Radiator in 91 CRX... Clearance for A/C???
I built a 91 CRX DX for my fiance about 2 years ago. I am in the process of getting a new radiator and I've decided to go with the OEM style replacement 90-93 Integra one after reading various posts. The car has a 96 B18B1 engine with 92 GSR YS1 tranny using HASport billet mounts and A/C with the stock D series compressor and HASport A/C bracket.
The mounts set the motor really close to the front which made putting the A/C in a little more challenging than expected. I had to remove the A/C fan shroud for clearance and this is with the stock LS header. I'm just wondering if anyone had this type of setup and are using the 90-93 Integra radiator and how tight the clearance is? I'd like to avoid buying a slim style fan if possible.
Old Sep 22, 2003 | 05:34 PM
HandCommand's Avatar
Default Re: 90-93 Integra Radiator in 91 CRX... Clearance for A/C??? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
The mounts set the motor really close to the front which made putting the A/C in a little more challenging than expected. I.</TD></TR></TABLE>
If you're using HaSport mounts and think there's no room up front, wait until you use other mounts like Place Racing which tip the motor forward!
I ran my stock A/C system using HaSports adapter plate using a 90-93 Integra Radiatior just fine. My stock B17 exhaust manifold came pretty dang close to the A/C lines.
I dont think the FAT stock A/C FAN would work. I was using the stock header with HaSport mounts and the clearance was tight. You may need to splurge on a SLIM FAN.
E38Mk1
Feb 23, 2014 10:57 AM
KtHaNxBai
Jun 17, 2012 08:50 PM
onimudvayne
May 22, 2008 04:01 PM
B2FiNiTY
Feb 26, 2004 07:18 PM
Oct 1, 2003 11:28 AM
