Any 450whp to 500whp+ cars out there on STOCK HEAD and valves with upgraded valvespings/ratainers?
Old Sep 22, 2003 | 02:30 PM
Boostfed's Avatar
New User
Default Any 450whp to 500whp+ cars out there on STOCK HEAD and valves with upgraded valvespings/ratainers?
OK as the topic states is there anyone out there preferrably over 500whp but 450whp works too that has a STCOK head and valves with only upgraded valve springs and ratainers? Reason I ask is I have a head that I feel is damaged that has oversized SS Ferrea valves and Skunk2 valve springs and retainers in it that I am gonna swap over to a stock head I have just not the valves due to time constarints to run this year at least. I have a new head being done by Brad with RLZ Engineering http://www.hondaraceengines.com but in the meantime I am thinking of doing this to run. Please no "Well why don't you use the valves too?" wuestions. Anyone? My whp is currently at 581.9whp and 381ft-lb torque 28psi with Full Race manifold, dp and Full Race T67 turbo. I don;t want to burn a valve which I know is comon on big shot Nitrous set ups. Thanks in advance H-T!
Old Sep 22, 2003 | 02:47 PM
alpha's Avatar
Default Re: Any 450whp to 500whp+ cars out there on STOCK HEAD and valves with upgraded valvespings/ratainer
I can't think of anyone off the top of my head but I will be running stock valves with a 465whp goal (or whatever it takes to run an 11.3).
Old Sep 22, 2003 | 02:52 PM
SiRkid's Avatar
you can do it!!!! :D
Old Sep 22, 2003 | 02:58 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">you can do it!!!! :D</TD></TR></TABLE>
Thanks for the SCIENTIFIC answer! Thanks Rob Schneider, I think "I can do it ALL NIGHT LONG!"
Old Sep 22, 2003 | 03:00 PM
Jared's Avatar
If you just want to do the least you can get by with, at least put stainless valves on the exhaust side. IMO stock exhaust valves arent up to the heat produced by a big turbo and nitrous engine.
Old Sep 22, 2003 | 03:01 PM
Boostfed's Avatar
New User
That was my thoughts on that Jared, we shall see.
Old Sep 22, 2003 | 04:04 PM
saso
Guest
Posts: n/a
I think it was Rocket or someone that said the stock valves are stronger than the SS. But when running larger valves SS is necessary for parts etc no OEM available.. I see no prob with running stock valves, I have but not at 581whp only at 400. Using the titanium retainers and valve springs would be a good idea for higher revs. There is now titanium valves (expensive) that would be stronger though. I cant give you a scientific but speak to Earl or Rocket if he still hangs around in this Forum.
Old Sep 22, 2003 | 05:40 PM
tony1's Avatar
On allen's car we only have springs and retainers and it made 520 at 25psi. We're going to try some new cams and a bigger turbo in hopes of closer to 600, but i think you can do it on stock sized valves...
Old Sep 22, 2003 | 05:45 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">On allen's car we only have springs and retainers and it made 520 at 25psi. We're going to try some new cams and a bigger turbo in hopes of closer to 600, but i think you can do it on stock sized valves...</TD></TR></TABLE>
Cool thanks this is what I want to hear. But not stock sized valves but STOCK VALVES actually. Tony????
Old Sep 22, 2003 | 05:52 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">This particular one is:
83mm 10:1 coated arias pistons
crower rods
stock gsr crank w/oem honda bearings
stock gsr head with skunk 2 springs and retainers
Jotech cam gears
stock gsr cams
JG Edelbrock intake manifold
72/70mm Ericks t/b
MSD 72lb injectors (soon to be upgraded to 1000cc)
Aeromotive fuel pump and regulator with sump on tank
Speed pro ems
MSD digital 6
Full-Race manifold
Precision sc61 with "S" compressor cover
3" downpipe w/v-band adaptor
custom 3" stainless exhaust
XS Engineering 24x11x3 intercooler
2.5" aluminum intercooler piping
Tial 40mm wastegate and Blow off valve
Tilton Dual disk clutch
Modified stock flywheel
Quaife Diff with gsr tranny
DSS stage 5 axles
I guess that answers my question up there huh? Stock valves but juts upgraded valvesprings and retainers! Hope for a short term until the end of the season.
Old Sep 22, 2003 | 05:54 PM
Rhman19's Avatar
So what you gonna do, throw on the spare head you got? Then have another one ported over the winter. Hopefully you'll be able to make it to the track this year.
Old Sep 22, 2003 | 05:55 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhman19 &raquo;</TD></TR><TR><TD CLASS="quote">So what you gonna do, throw on the spare head you got? Then have another one ported over the winter. Hopefully you'll be able to make it to the track this year. </TD></TR></TABLE>
Exactly like I said above Brad from RLZ Engineering is doing it http://www.hondaraceengines.com
Old Sep 22, 2003 | 06:08 PM
Rob Dizzle's Avatar
brad knows his ****, what did he say regarding the setup?
i hope you arent going to reuse those skunk2 springs...
Old Sep 22, 2003 | 06:10 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 &raquo;</TD></TR><TR><TD CLASS="quote">brad knows his ****, what did he say regarding the setup?
i hope you arent going to reuse those skunk2 springs...</TD></TR></TABLE>
LOL! He said get rid of them too! I sold them but will use them temporarily in my set up until he finishes my head for me. He wants me to run his springs and retainers also valves too, I will trust him on it plus the deal he is giving me is "An offer I can't refuse!"
Old Sep 22, 2003 | 06:28 PM
GSRswapandslow
Guest
Posts: n/a
at least you went smart on the head...
Brad is BY FAR the BEST
Old Sep 22, 2003 | 06:29 PM
Boostfed's Avatar
New User
Default Re: (GSRswapandslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow &raquo;</TD></TR><TR><TD CLASS="quote">at least you went smart on the head...
Brad is BY FAR the BEST</TD></TR></TABLE>
I think I heard voices or something telling me to go to him, It's like in the headporter thread I heard his name like 3000 times y0!
Old Sep 22, 2003 | 06:38 PM
ekb18c's Avatar
Default Re: (Boostfed)
you should be alright with stockers on for now.
And yes your goal is obtainable.
Old Sep 22, 2003 | 06:40 PM
GSRswapandslow
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">
I think I heard voices or something telling me to go to him, It's like in the headporter thread I heard his name like 3000 times y0! </TD></TR></TABLE>
haha, that's because ppl are finding out about him. he's a lot ******* better and cheaper that **** like portflow or that "a" named place. He's better than Larry too.
Old Sep 22, 2003 | 06:48 PM
T4eg's Avatar
you could accomplish that with stock valves. Its not as important on FI and All motor. FI just crams air in.
Old Sep 22, 2003 | 07:45 PM
SiRkid's Avatar
Default Re: (BlueHatch00)
I told you
Old Sep 22, 2003 | 07:49 PM
Boostfed's Avatar
New User
Default Re: (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">I told you </TD></TR></TABLE>
You H-T guys are ALL SOOO SMART!
SirRevvs
Oct 14, 2010 10:32 AM
AntMan401
Mar 17, 2008 02:13 PM
red91g2
Dec 15, 2002 07:59 PM
Trajic
Jul 4, 2001 01:13 PM
