Main bearing problem
Old Sep 22, 2003 | 12:16 PM
drewlee's Avatar
Default Main bearing problem
I just ordered some main bearings from acuraautomotiveparts.org and the guy sent me a email saying
"I will need to know what color(thickness) main bearings you need. The wrong size will damage your crank. Check your service manual, there should be a chart for that. "
I bought the ls block from the junkyard and dont have the service manual. The block was from a 91 acura integra 4dr ls does anyone know what the "color(thickness) is"?
drew-
Old Sep 22, 2003 | 12:18 PM
19924ws's Avatar
No one can tell you, only you can fig it out. There are numbers stamped on the crank and numbers stamped on the block. You have to use those 2 (one from block and one from crank) numbers and use the chart in the manuel. OR you could post the numbers from both and someone with a manuel could help you.
eg6-jarhead
Mar 31, 2012 06:00 PM
superjet
Aug 4, 2010 07:55 AM
mrbsponge
May 3, 2006 07:54 AM
brokenojoke
Dec 22, 2005 09:25 AM
cal_
Feb 6, 2005 12:32 AM
