CTR Pistons in b16 w/ mugen head gasket.. will it hit?
I'm gonna clay it eventylly... I just want to know if I should spend the extra chedda on the mugen gasket.... I have b16 with Civic Type R pistons. I still want to run on pump gas which I'm told shouuld still work with this setup. Compression should be about 11.2 with the mugen gasket. I shouldn't have piston valve issues though right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nmhybridog »</TD></TR><TR><TD CLASS="quote">Compression should be about 11.2 with the mugen gasket. </TD></TR></TABLE>
fyi, with CTR pistons and a stock head gasket CR is higher than that. I forget exactly but closer to 11.5:1. That's been a heavily debated issue but those in the know say it's pretty high.
s
s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel »</TD></TR><TR><TD CLASS="quote">
s</TD></TR></TABLE>
yeah it is higher because the deck height of the b16a block is shorter than the b16b block
s</TD></TR></TABLE>
Dohcvtec59
Oct 15, 2004 04:44 AM
Dohcvtec59
Sep 14, 2004 05:48 PM
