Which V-tec selonoid seal for JDM b16?
Old Sep 22, 2003 | 06:16 AM
hughesl's Avatar
Default Which V-tec selonoid seal for JDM b16?
My vtec seal is leaking and I want to order a replacement. Does the 94 del sol work? or should I order a different one.
Thanks for the help.
Old Sep 22, 2003 | 06:23 AM
Hybridize's Avatar
Vtec seal? You mean the seal around the VTEC soleniod is leaking?
Not saying it's not, but I'd get a set of cam seals and replace them while you're in there too. They might be the culprit for the leak.
My cams seals are leaking right now too, I have the seals just been too lazy to tear her down to put em in.
Old Sep 22, 2003 | 08:56 AM
zCivic's Avatar
Default Re: Which V-tec selonoid seal for JDM b16? (hughesl)
all B series v-tec sols are the same
Old Sep 22, 2003 | 11:38 AM
Phatwhippin_CRX's Avatar
Default Re: Which V-tec selonoid seal for JDM b16? (zCivic)
which is why some people use a prelude VTEC solenoid.... not sur eif it actually makes any difference though
Old Sep 22, 2003 | 11:40 AM
incubus's Avatar
my VTEC solenoid seal is leaking also, at least I think that is what it is... I have seen oil coming straight from it so I assume so, I just replaced all my other gaskets so I amm ssuming that is the case. damn thing wish I woulda knew about it when I changed my Valve cover gasket!
Old Sep 22, 2003 | 01:08 PM
shadowstylz's Avatar
Default Re: Which V-tec selonoid seal for JDM b16? (incubus)
I ordered a 2000 acura integra gsr vtec silenoid gasket from acura, and it worked great on my jdm b16a . stop the leak completly
Old Sep 22, 2003 | 01:14 PM
hughesl's Avatar
Default Re: Which V-tec selonoid seal for JDM b16? (shadowstylz)
Thanks for the input guys. I do plan to replace the cam seals as well. It looks like both are currently leaking a little. Any of you replace the cam seals with the billet and o-ring type? If so are you completely happy with them?
Ratchback
Feb 26, 2006 01:10 PM
jvonb
Dec 29, 2005 06:25 AM
Jammersplace
Jun 4, 2004 06:41 PM
memphiss13
Nov 25, 2001 02:44 PM
