can i run a ACT 6 puck unsprung disc with stock Pressure plate?
Old Sep 22, 2003 | 12:26 AM
SofaKing's Avatar
Default can i run a ACT 6 puck unsprung disc with stock Pressure plate?
like the topic says.
i have a GSR swap and am too poor right now to afford the clutch package so i just ordered the disc. (act 6 puck metalic disc unsprung) i ran this clutch before in my GSR'ed EK and loved it.
--just wondering whats gonna happen if i use the disc in the stock GSR pressure plate? i think it will work fine,, but thats just me, anyone with experience???
thanks to all that help me out.
Old Sep 22, 2003 | 06:54 AM
SofaKing's Avatar
Default Re: can i run a ACT 6 puck unsprung disc with stock Pressure plate? (SofaKing)
Anyone?
Old Sep 22, 2003 | 02:14 PM
SofaKing's Avatar
echo echo echo
Old Sep 22, 2003 | 02:22 PM
pro1342's Avatar
It's kinda worthless....and the plate will probably fail.
Old Sep 22, 2003 | 06:06 PM
Paluce's Avatar
why did you get that disk if you can't afford a pressure plate??? Wait till you can get a pressure plate and do it right. you can use it, but I wouldn't recomend it.
Old Sep 22, 2003 | 08:41 PM
SofaKing's Avatar
Default Re: (Paluce)
why no recomemdation?? slippage you think? eh, i guess ill see what happens.
anyone else?
Old Sep 23, 2003 | 12:19 AM
fox297's Avatar
Default Re: (SofaKing)
I don't see why you can't do it, but it's probably not gonna last long.
Old Sep 23, 2003 | 08:09 AM
pro1342's Avatar
I think the low pressure of the stock plate will cause the plate, or disk, to glaze and start slipping right away.
Old Sep 23, 2003 | 08:50 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Re: (fox297)
You will more than likely need a new pressure plate quick if use stock with a 6 puck disc.
I know Supra people that use triple plate clutches with stock or organic PP's.
It's nice if you want the stock pedal pressure, but you'll be replacing it alot.
Old Sep 23, 2003 | 11:09 AM
Crazydave's Avatar
Default Re: (Knightsport)
a sprung 6-puck with stock pressure plate is horrible and is a pain in the ***..
stick with your stock clutch it will work just as well, it will be easer to drive, and will last MUCH longer like 5 to 10 years longer
Old Sep 23, 2003 | 12:41 PM
SofaKing's Avatar
Default Re: (Crazydave)
eh, i dont want to keep the stock clutch, im prolly pushing 180ish WHP and im spraying a 100 shot... its not going to last very long.
DX Hybridizer
Jun 7, 2005 08:46 PM
Absentmind
Jun 23, 2004 08:53 PM
chingchong
Mar 30, 2003 09:18 PM
chingchong
Mar 30, 2003 08:59 PM
