Crx Idle
Old Sep 21, 2003 | 11:13 PM
byathread's Avatar
Default Crx Idle
I just got a 1991 crx si. its stock and i think its idling low. what should it be set at its around 750 now. thanks.
Old Sep 21, 2003 | 11:22 PM
Malgerus's Avatar
Default Re: Crx Idle (byathread)
750 is perfect...
Old Sep 21, 2003 | 11:52 PM
byathread's Avatar
Default Re: Crx Idle (Mr. S)
but it seems to shake alot when im at a stoplight that normal?
Old Sep 22, 2003 | 12:45 AM
jdwebmaster's Avatar
depends on the shake, my car does it but i need a valve job and the distributers cap and rotor replaced. how bad is the shake?
Old Sep 22, 2003 | 06:48 AM
byathread's Avatar
Default Re: (jdwebmaster)
it was really bad because the idle was around 500 so i turned it up to 750
Old Sep 22, 2003 | 08:28 AM
88whitehf's Avatar
Default Re: (byathread)
It might be shaking alot because of your motor mounts?? Not sure but 750 is good maybe alittle higher. Have you checked your timing to make sure that was right on because if its not then you could receive a rough idle. my .02cents
chris
Old Sep 22, 2003 | 10:03 AM
byathread's Avatar
Default Re: (88whitehf)
alright i will do that thanks
Old Sep 23, 2003 | 08:37 AM
Malgerus's Avatar
You can set the timing properly by unplugging the IACV and turning the idle up to 750.
2ndgenaccord
Classic Hondas
Jan 20, 2013 12:57 PM
Acemcguyver
Classic Hondas
Jun 2, 2008 01:39 AM
mattwarden
Jan 25, 2008 12:36 PM
fireant
Oct 11, 2006 07:26 AM
JohnnyLux
Nov 4, 2004 08:35 PM
