jdm type r or p30's?
Old Sep 21, 2003 | 07:59 PM
philafelman's Avatar
Default jdm type r or p30's?
im doing an mild all motor setup to my gsr motor...should i throw in jdm type r pistons or jdm p30 pistons in there...ive heard the p30's give a little more compression, but are they as strong as the r's? also, i am planning on running skunk 1's, what compression do they work the best with? should i do type r or skunk valvesprings/retainers, and do they make any power past 8500rpms?
Old Sep 22, 2003 | 05:21 PM
Default Re: jdm type r or p30's? (philafelman)
nobody has any info for me??
Old Sep 22, 2003 | 05:49 PM
dc2twincam's Avatar
im running p30s in my set up.....my compression is at 11:6 slightly higher than p73-00, but i suggest you run stage 2 cams...........
Old Sep 22, 2003 | 06:01 PM
91tegrals's Avatar
wat about ctrs..
Old Sep 22, 2003 | 06:42 PM
dc2twincam's Avatar
Default Re: (91tegrals)
12:1 in a b18c1 block with the p72 head......
Old Sep 22, 2003 | 06:50 PM
JDM_Risa's Avatar
Default Re: (dc2twincam)
sup i got the same question .........p30s or jdm itr...........i am running skunk s2 right now......i need some real compression my comrpession right now is killing me.........how strong is the p30 compared to the jdm itr
Old Sep 22, 2003 | 08:51 PM
dc2twincam's Avatar
Default Re: (GunMETAL_TEgRa)
well horspower wise, i wouldn't know....but if you're looking for some crazy compression......you can always go ctr pistons for 12:0 compression it also depends on how much you drive the car(gas wise)....sticking jdm itr pistons into the gsr(b18c1) will give higher compression than the b18c5 due to the gsr head........
comteg396
Dec 25, 2004 02:51 AM
jdm jedi
Apr 23, 2004 07:58 PM
Heisdan
Aug 4, 2003 07:07 AM
Eckz2k
Mar 7, 2003 11:37 PM
Ri5e
Feb 13, 2002 04:51 AM
