Easy way to remove rod caps?
Old Sep 21, 2003 | 07:18 PM
Bnjmn's Avatar
Default Easy way to remove rod caps?
I'm trying to plastigage my rods but I'm having a hell of a time removing the caps without moving that around so much that I ruin the plastigage. Is there a trick to easily taking them off?
Pistons are installed, crank is on the mains, and I'm pulling up the rod bolts and wiggling/hitting the bolts with a plastic hammer to get the cap off.
Any other suggestions?
Thanks
Ben
Old Sep 21, 2003 | 07:26 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Easy way to remove rod caps? (Bnjmn)
if u look on the bottom of the bolts on the rods there are tiny dimples..use a small punch or chuck and a hammer and GENTLEY tap each side (where the dimples are) 1 after the other till the cap is seperated from the plastigauge then it should be loose enough to wiggle it off..works for me every time........
ps.... im editing this post since im a "trial user" and only alowed 5 post per 24hrs...since u have manleys....just un screw the bolts (so basicaly there just sitting insinde the rod holes and tap down on the bolts with a plastic hammer or a peice of wood and a metal hammer.LIGHTLEY and they should slowly seperate the caps fome the rods(so basically the bolts are pushing the rods down off the caps)...hope that helped..
Modified by bruceleeroy at 2:03 AM 9/22/2003
Modified by bruceleeroy at 2:06 AM 9/22/2003
Modified by bruceleeroy at 3:36 AM 9/23/2003
Old Sep 21, 2003 | 09:21 PM
Bnjmn's Avatar
Default Re: Easy way to remove rod caps? (bruceleeroy)
I have Full Race/Manley rods...I don't see the dimple you are talking about or a way to use a punch on them. Any other ideas?
Thanks
Ben
Old Sep 22, 2003 | 11:17 PM
SYD's Avatar
SYD
edited above post /\ hope that helps..
Old Sep 22, 2003 | 11:30 PM
IN VTEC's Avatar
We've had the same problem on a set of P72 rods with ARP 2000 9mm bolts b/c pressing the rod bolts warped the big-end. The out-of-roundness was corrected by align-honing, but the change in bolt orientation made it really hard to get the caps off.
Eventually I just had to put the bearings in, put the cap on, stretch the rod bolts in the table clamp, and measure the clearance with a dial bore gauge and micrometer.
You might also consider putting a slight chamfer on the inside radius of the rod cap to help keep it from binding on the threads when trying to move the caps up and off the rods.
Old Sep 22, 2003 | 11:53 PM
SYD's Avatar
SYD
Default Re: Easy way to remove rod caps? (IN VTEC)
i had that same problem with some gsr rods and arps but resizing took care of it....but he has manleys so his problem is different.
Old Sep 23, 2003 | 07:53 AM
IN VTEC's Avatar
Same issue....the caps like to bind on the rod bolts.
Might also try lubing the shanks of the rod bolts to keep the caps from sticking to the rod bolts.
Old Sep 23, 2003 | 07:55 AM
Bnjmn's Avatar
Thanks guys. I'll lube the shanks and go to work on them with my plastic hammer and hopefully it won't be too frusterating.
Update-
Plastic hammer on the rod bolts (sticking up on the upper half of the cap) works wonders. After a few good hits they literally pop off and reading plastigage is easy.
Thanks
Ben
Modified by Bnjmn at 12:58 AM 11/9/2003
Old Jan 29, 2004 | 12:24 PM
Ryan C's Avatar
Back From The DEAD!!!!
thanks to SEARCH
saved me a huge headache today!
GSR and ARP 9mm same problem
Old Jan 29, 2004 | 12:33 PM
IN VTEC's Avatar
Default Re: Easy way to remove rod caps? (Ryan C)
Something else we tried was putting the plastigage on the other side of the journal to keep it from being squashed when knocking the rod down.
89s1
Jan 12, 2008 05:56 AM
GSRCRXsi
Apr 1, 2006 10:24 PM
IN VTEC
Nov 27, 2003 12:59 PM
vtec69
Sep 28, 2002 07:27 PM
