type r third gear different?
Old Sep 21, 2003 | 06:35 PM
$#$%$*$'s Avatar
Default type r third gear different?
is the third gear in a type r different from other vtec hondas?
im wondering if the gear ratios are different and thats why the third kicks so hard
if its not that, then what is it about their third gear thats makes them so demonic!?
Old Sep 22, 2003 | 02:12 AM
MiraiZ's Avatar
Default Re: type r third gear different? ($#$%$*$)
Flame suit on...
IBTL
Old Sep 22, 2003 | 02:28 AM
Ph0eNix's Avatar
Default Re: type r third gear different? (MiraiZ)
Old Sep 22, 2003 | 02:57 AM
01-1293's Avatar
Default Re: type r third gear different? (Ph0eNix)
Type R third gear is equipped with a NOS regulator
Old Sep 22, 2003 | 03:37 AM
MiraiZ's Avatar
Default Re: type r third gear different? (01-1293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-1293 &raquo;</TD></TR><TR><TD CLASS="quote">Type R third gear is equipped with a NOS regulator</TD></TR></TABLE>
don't listen to this guy...Type R's 3rd 4th an 5th gears have a flux capacitating torque amplifier, that directly interacts with the VTEC to give and instantaneous 100ft/lbs of unregulated torque. Thats why there is no need for a turbo...although I prefer one.
This also allows the limited slip differential to engage to give added traction to all four wheels. Then when the helicitical gears engage, the R is able to turn 35 degrees sharper. So in turn its better than AWD...its R wheel drive!
so to answer you question...yeah it is different...sorry for getting all techincal. I would explain it in more simpler terms, but it'll take too long.
AllMTRWH0R3
Jan 24, 2005 11:52 AM
EK-Chris
Jan 13, 2005 09:35 PM
