Which High Compression Pistons with Toda C'ssssssssssssss
Old Aug 23, 2001 | 01:36 PM
powerfulperformance's Avatar
Default Which High Compression Pistons with Toda C'ssssssssssssss
with there be any valve clearance issues if i use any other pistons that toda pistons. I want to find out because toda said there piston is the only high compression compatible with there toda c.....
Old Aug 23, 2001 | 01:45 PM
adam's Avatar
Default Re: Which High Compression Pistons with Toda C'ssssssssssssss (powerfulperformance)
CTR pistons will do nicely
Old Aug 23, 2001 | 01:51 PM
Black R's Avatar
25 Year Member
everybody is gonna tell you rollerwaves in 12.5:1..... just a warning
Old Aug 23, 2001 | 02:29 PM
FAST94GSR's Avatar
New User
Default Re: Which High Compression Pistons with Toda C'ssssssssssssss (Black R)
You really have to check and see if the valve pockets are deep enough. Endyn/Wiseco pistons will work. CTRs will work. Just don't mill your head.
Old Aug 26, 2001 | 08:41 PM
Can I use rollerwaves and where can i get it from...
Old Aug 26, 2001 | 08:43 PM
Type Goch's Avatar
New User
try visiting their website. http://www.theoldone.com
Old Aug 26, 2001 | 09:44 PM
Mike M's Avatar
Founding Member
Default Re: Which High Compression Pistons with Toda C'ssssssssssssss (Type Goch)
All the above pistons, Also of course the Toda Pistons Which is what I am using
Old Aug 26, 2001 | 10:18 PM
ElectronVTEC's Avatar
Default Re: Which High Compression Pistons with Toda C'ssssssssssssss (TypeRmsm)
I saw a fubarred Rollerwave and Eagle/Endyn rod this weekend. All in a B16A that's making 180 whp top. I'm still not convinced... EV.
Old Aug 27, 2001 | 04:23 AM
JDM_DOHC_SiR's Avatar
New User
Default Re: Which High Compression Pistons with Toda C'ssssssssssssss (ElectronVTEC)
I have used SRP and ARIES before with the C/R of 11.3:1 but both of these companys pistions were nice but too noisy for my liking ...I just swiched to the Wesico Endyn Units with a 12.3:1 C/R and they are very nice I had Larry cut the valve pockets deeper for when I go up te the Toda C's this winter. but they wil; work fine with the B spec's..
Old Aug 27, 2001 | 04:30 AM
Lip's Avatar
Lip
my rollerwaves work fine with my C's
241.9whp with 159.1ft lbs of torque
Old Aug 27, 2001 | 04:36 AM
FSTASNTZ's Avatar
Yup, the 12.5:1 Endyn/Wiseco pistons work just fine with the Cs. 9500 RPMs and no problems.
Jason
Professor15
Mar 15, 2005 04:39 PM
itr_18
14
Jul 7, 2004 04:21 PM
AllMotorITR
Oct 23, 2001 08:36 PM
ITR111
Sep 30, 2001 01:37 PM
