HELP!! No Guage Cluster Readings... All Lights No readings...
Old Sep 21, 2003 | 05:28 PM
crxman00's Avatar
Default HELP!! No Guage Cluster Readings... All Lights No readings...
I just took my tranny out and put it back in. And now I have no readings from my stock Guage Cluster. My External Tach works fine. Any ideas
THANKS in advance
Old Sep 21, 2003 | 05:32 PM
CRneXt's Avatar
Default Re: HELP!! No Guage Cluster Readings... All Lights No readings... (crxman00)
This is going to be a long shot, but check your fuses. the same thing happened to me, after I did a tailight lens replacement... I had a wire pinched in between the lens and the body of the car. Had a small amount of trouble tracing it down though.
You might have a similar problem... Wire pinched popping fuses. Bet you don't have brakelights either.
Just trying to help,
Scott
Old Sep 21, 2003 | 07:49 PM
crxman00's Avatar
Default Re: HELP!! No Guage Cluster Readings... All Lights No readings... (CRneXt)
I just found the two wires that plug up for your reverse lights pinched between the block and the tranny housing. I am going to have to cut and clip-connect them. Hopefully they just blew a fuse...
Old Sep 21, 2003 | 09:08 PM
CRneXt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxman00 &raquo;</TD></TR><TR><TD CLASS="quote">I just found the two wires that plug up for your reverse lights pinched between the block and the tranny housing. I am going to have to cut and clip-connect them. Hopefully they just blew a fuse...
tadaa!!!
I am glad when a problem resolves well.
Scott
EG6_978
Apr 4, 2010 12:56 PM
slow_cx
14
Dec 10, 2007 10:08 PM
Steven.
Oct 7, 2006 01:04 PM
See Are X
Oct 22, 2005 10:50 PM
newspeedR
Sep 20, 2002 06:47 AM
