Need help on replacing coolant
Old Aug 23, 2001 | 01:26 PM
Pat's Avatar
Pat
Default Need help on replacing coolant
I'm going to replace my coolant for the first time (at 25k miles, ~3yrs). Should I just drain and refill or should I do a flush with water as well (not a chemical power flush or anything). Looking at the Helms and Haynes manual, flushing seems to involve a lot more work ie: taking out the thermostat and hoses and such. THe Helms doesn't even cover flushing.
Also should I use distilled water to mix coolant or will tap water suffice? And should the heater temp be on max and blowing air the whole time I do this?
Thanks for any help!
Old Aug 23, 2001 | 08:28 PM
clockworks's Avatar
Default Re: Need help on replacing coolant (Pat)
Just drain the coolant and leave the draincock open, then take a garden hose and spray into the radiator. After a minute or so of doing that, close the draincock and fill up to the top with water. Leave the cap off and start the car, let it warm up until the thermostat opens and add more water until the radiator is full again. Rev it a bit, then drain the water. Fill it up with 50/50, bleed it, and cap it off. Done.
HTH,
Greg
Old Aug 24, 2001 | 06:30 PM
GruvyTune's Avatar
New User
Default Re: Need help on replacing coolant (clockworks)
have any of you ever been able to get the engine block plug open?? Damn, there's no clearance in there to get a good socket on it.
Old Aug 24, 2001 | 07:02 PM
BreakStuff's Avatar
New User
Default Re: Need help on replacing coolant (GruvyTune)
I've gotten plenty of them off.. of course in my cases, the head was removed
Old Aug 24, 2001 | 07:39 PM
Gasoline Fumes's Avatar
I've used a wrench or a short socket.
Old Aug 24, 2001 | 09:25 PM
clockworks's Avatar
I never worried about it, I just disconnect the lower rad hose at the water pipe, and jack up the driver's side of the car. Most of the coolant flows out.
Peace,
Greg
mjf6866
Nov 10, 2010 07:37 PM
SamC
Dec 8, 2007 07:55 AM
Quik89Si
Jan 3, 2005 07:06 PM
Andrew Sites
Oct 7, 2001 08:36 PM
Pat
Aug 23, 2001 08:33 PM
