ignitor, code 15, dont think its the distributor.
where is the ongoing post
https://honda-tech.com/zerothread?id=612197
well its a code 15. but no check engine light. I just happened to look at the ecu and clear the code. I have replaced the distributor with a brand new one. my question is which color wire and which connector(small round 2 pin or large round 7 pin)also does this wire go directly go to the ecu? thanks
two white wires in the 7 pin round connector go to the ECU - one is for the ignitor and one is for the crank angle sensor
is ther any grounds wires for that plug for the large 7 pin plug? because we had to cut and move the ground for the 2 pin plug on the distributor to get it to first start when we first put the swap it.
Sobe_Death
Mar 11, 2004 10:09 AM
red civic standard
Dec 14, 2002 06:00 AM
