Whats wrong with my LSD !!!!! NEED HELP!!!!!
Old Sep 21, 2003 | 04:12 PM
boosted_zc's Avatar
Default Whats wrong with my LSD !!!!! NEED HELP!!!!!
I finally got my built ZC finished and went to go break in the motor. I have a L3 LSD ( i think that's what it's called). Basically if i go slow it's ok, but if i give it some gas it goes absolutely nowhere, stutters like crazy. What the hell is wrong with this thing. I have 89 Integra axles and hubs ( by the way it's a 91 hatch) , it's exactly the same setup i had when my old ZC was in so it can't be that. Any help would be great. Thanks
Old Sep 22, 2003 | 04:47 AM
TimoneX's Avatar
New User
Default Re: Whats wrong with my LSD !!!!! NEED HELP!!!!! (boosted_zc)
You're certain the clutch is healthy? No slipping?
Old Sep 22, 2003 | 09:06 AM
boosted_zc's Avatar
Default Re: Whats wrong with my LSD !!!!! NEED HELP!!!!! (TimoneX)
Brand new stage 3 ACT clutch, healthy as it could be.
Old Sep 22, 2003 | 10:51 AM
1bad-eg's Avatar
Are you sure it's your lsd?
Old Sep 22, 2003 | 12:17 PM
owen_the_soyboy's Avatar
timing belt off one tooth?
Old Sep 23, 2003 | 06:49 PM
boosted_zc's Avatar
Default Re: Whats wrong with my LSD !!!!! NEED HELP!!!!! (owen_the_soyboy)
Found the problem with the LSD, took it apart, there was a friggin 10 mm bolt bouncing around in there. Don't ask me how it got there but it was there. Hopefully all will be solved now.
Old Sep 24, 2003 | 12:32 PM
PupaScoopa's Avatar
That's always nice to have a bolt loose in your transmission
Old Sep 24, 2003 | 05:59 PM
boosted_zc's Avatar
Default Re: Whats wrong with my LSD !!!!! NEED HELP!!!!! (PupaScoopa)
i don't believe it originated from inside the tranny. The speedo cable attachment part is missing in my trans so i'm guessing that's how it got there. It was open when i got it, i covered it so i know i didn't drop it in there. Know i just need to get that piece, gonna need it anyway if i wanna know how fast i'm goin'.
Old Sep 25, 2003 | 03:34 AM
1bad-eg's Avatar
Good thing you found it before it caused any serious damage.
Old Sep 25, 2003 | 07:24 AM
advanracing62's Avatar
Default Re: Whats wrong with my LSD !!!!! NEED HELP!!!!! (1bad-eg)
"what's wrong with my lSD?"
maybe you didn't skim it enough... or let it set- why are you getting stomache cramps?
Glad you found the issue
DmcL
Jan 20, 2007 06:22 AM
fjt
Dec 7, 2005 06:32 AM
boosted_zc
Sep 22, 2003 09:04 AM
*Boostwerks*
Feb 23, 2003 09:36 PM
rexinfection
Oct 21, 2002 01:16 PM
