Loud "click" in left front suspension
Old Sep 21, 2003 | 02:48 PM
k_carpenter's Avatar
Default Loud "click" in left front suspension
I have a clicking that happens in my left front suspension, at least that area, and i cant figure out what the hell it is! Ive got a 94 ls, skunk 2s with camber kits around. it happens when i turn the wheel to leave a parking spot. when i turn to the right it clicks at just about full turn then clicks again when i turn back to the left to take off. it also happens when i go over speed bumps every now and then.
Ive had my wheel off at least 5 times checking everything out! everything is tight.
I have a feeling it might have to do with my cv joint, but it isnt making the cv crazy noise yet. and i cant explain why it clicks over bumps every now and then.
help me out!!! i dont want to take it to a shop and have some *** rob me of all my money cause i cant figure this one out.
Old Sep 21, 2003 | 02:51 PM
threatcon13's Avatar
New User
Default Re: Loud "click" in left front suspension (k_carpenter)
same thing happened to me after i installed my ingalls camber kit. Everytime i would turn the wheel all the way while leaving my parking space, i would hear a loud popping noise from the front right or left side. the camber kit was loose...tightened it up and the "popping" noise went away.
Old Sep 21, 2003 | 03:44 PM
B2FiNiTY's Avatar
Could be your cvs or axle.
Old Sep 21, 2003 | 05:46 PM
Chemicalviper's Avatar
axle
Old Sep 22, 2003 | 06:42 AM
4U2NV's Avatar
My guess would be CV boot... Usually when they bust, the grease leaks out and won't make any noise for a couple of weeks until all the grease is gone and the bearings become dry... That's prolly the stage where you're at, and that's why you're hearing the popping/clicking noise...
I'd reccomend getting it fixed fairly quickly, and stay away from U-Turns... HTH...
Old Sep 22, 2003 | 06:53 AM
conesmasher's Avatar
Default Re: Loud "click" in left front suspension (4U2NV)
Try the ball joint, just a suggestion, but my buddy is having the same problem right now.
Old Sep 22, 2003 | 07:54 AM
IN VTEC's Avatar
It could also be a binding swaybar endlink.
Mine had been damaged somewhere along the line and I found it one day when I separated the front endlinks....really gritty when you try to rotate the endlink.
Old Sep 22, 2003 | 09:36 AM
Full Race EG's Avatar
Default Re: Loud "click" in left front suspension (IN VTEC)
axle
Old Sep 22, 2003 | 09:57 AM
Lenn77's Avatar
Default Re: Loud "click" in left front suspension (IntegraLStuner)
Its the Axle, I had that problem for a while till my axle broke
Shirozu
May 31, 2010 08:36 PM
HALFretarded
Jun 12, 2008 11:24 AM
Shake and Bake
17
Mar 2, 2006 09:10 AM
vgsr
May 29, 2005 09:26 PM
Stein
Aug 16, 2004 07:48 PM
