rough idle...
Old Sep 21, 2003 | 01:37 PM
See Are X's Avatar
Default rough idle...
my idle jumps around from 400-800 rpms when the motor is warmed up. When its cold, it idles fine around 1200 rpm. When its warmed up, sometimes it'll even stall out. My setup is a 2000 B16 in a 92 civic hatch. Running a chipped P28. With no CEL at all. What could it be?
Old Sep 21, 2003 | 02:42 PM
t04ecvc's Avatar
Default Re: rough idle... (See Are X)
Intake idle sensor is bad. Usually the symptoms when it craps out.
Old Sep 21, 2003 | 09:18 PM
See Are X's Avatar
Default Re: rough idle... (t04ecvc)
oh...i forgot to mention...I added a Intake Air Temperature sensor since the b16a2 doesnt have one...maybe i didnt wire it up right? or the sensor could be bad? is there a way to check that sensor?
Old Sep 22, 2003 | 04:37 PM
See Are X's Avatar
up
Old Sep 22, 2003 | 05:05 PM
poison's Avatar
Could possibly be the IAT, but I would rcommend you clean the IACV with carb/brake cleaner and cleaning the IACV screens if you do not have any CEL's.
Old Sep 22, 2003 | 05:16 PM
da9JDMls's Avatar
Default Re: rough idle... (poison)
You may want to check the IACV... idle air control valve on the back on the Intake Manifold, teh O-ring that seals it to create proper vacuum may be bad.. mine was... mine Idle was all messed up... hope I helped
GSRicer
Jul 5, 2009 08:34 PM
EJuno
Feb 5, 2008 06:20 PM
5thGeneration
Jan 3, 2008 01:49 PM
Bboy_Trevstuh817
Jan 7, 2007 10:31 PM
red-crx
Feb 8, 2006 02:56 PM
