Blown head gasket again?????help
I've got a d16a6 with greddy kit already had the head gasket go once....so put a new one on and the boost has set at 5lbs since...we replaced it maybe like a month ago...welp the timing has been at 12degrees and 5lbs of boost since...welp all of a sudden the car started idling real rough and i started seeing some ***** smoke from the back but it smells like gas....I didnt see any milky white in the oil cap or dipstick. any opinions would be welcomed!
i had a problem like that once.....
white smoke,,,,, not coolant.... nor oil... replaced my headgasket and still there...
turned out to be a fractured wire of an injector... let my injector Open all the time.... white smoke was crude fuel......
but in ur case.,.. ur boosted...but still.... make sure u are not overflodding the engine
is it wasting gas?
is it wasting gas?
It does seem to be running rich...and thier is a lot of gas smell int he white exhaust but I think im losing coolant now so this maty have answered the problem.....prolly cracked block
Clash0901
12
Jun 6, 2010 01:36 PM
