Clutch squeaks when it grabs..
Old Sep 21, 2003 | 11:58 AM
Azhten's Avatar
Default Clutch squeaks when it grabs..
My clutch squeaks when I'm starting in 1st gear from a stop and shifting into 2nd. Seems like something needs to be lubed up. Can soemone tell me what I need to do? thanks
Old Sep 21, 2003 | 12:29 PM
RCautoworks's Avatar
Default Re: Clutch squeaks when it grabs.. (Azhten)
How do you know its by the clutch area ? Sure its not a belt or anything like that. If it is coming from the trans, It could be the flywheel bearing.
Old Sep 21, 2003 | 12:36 PM
Azhten's Avatar
Default Re: Clutch squeaks when it grabs.. (90blackcrx)
I just assumed it had something to do with the clutch because It only happens when I let it out.
Old Sep 21, 2003 | 09:01 PM
Azhten's Avatar
anyone?
Old Sep 21, 2003 | 09:35 PM
Padawan's Avatar
Darth ModerVader
Is it an aftermarket clutch?
Old Sep 21, 2003 | 11:11 PM
Azhten's Avatar
Default Re: Clutch squeaks when it grabs.. (Padawan)
Yes, It's a clutchmasters
Old Sep 22, 2003 | 05:57 AM
typer_801's Avatar
It's usually where at the front where the servo line meets with the release fork underneath the rubber boot. It gets dry and squeaks when depressing the clutch. Happened to me in my R
You may need to remove the servo to get good access, but what you need to do is use Honda Urea grease to place a small amount in the depression of the release fork and maybe a touch on the ball of the servo, put them back together and all should be well again.
Old Sep 22, 2003 | 07:14 AM
Default Re: Clutch squeaks when it grabs.. (typer_801)
Replace the flywheel bearing and lube up the throw out bearing.
Old Sep 22, 2003 | 07:22 AM
jerseybrandon's Avatar
Its also common for performance clutches to "chirp" a bit.
Old Sep 22, 2003 | 08:01 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azhten &raquo;</TD></TR><TR><TD CLASS="quote">Yes, It's a clutchmasters</TD></TR></TABLE>
Sounds like it might just be a normal noise of the clutch. My brother's Exedy race makes what some might describe as a "squeak" (although it isn't actually squeaking) when engaging from a stop.
Old Sep 22, 2003 | 09:31 AM
WuRKD b16's Avatar
YO clutch masters squeak so dont be scurred. mine does da same thing. i should of went wit ACT
Old Sep 22, 2003 | 11:07 AM
Azhten's Avatar
How do I remove the servo?
Old Sep 22, 2003 | 11:37 AM
VtecDA9's Avatar
Default Re: Clutch squeaks when it grabs.. (WuRKD b16)
ACT squeeks too
Old Sep 22, 2003 | 12:10 PM
Azhten's Avatar
Yeah, that's the best way I could describe it, so it's normal?
Old Sep 22, 2003 | 12:25 PM
WOTTEG's Avatar
My OEM Clutch [ 2000 Integra LS 45k miles ] "chirps" as I let off the pedal and accelerate.
It does this most noticably in the lower gears (1,2,3).
It's been doing this for about 10k miles [I'd guess].
I assume it is the clutch because I only hear it with the windows open, and it doesn't make the noise if the transmission is not in gear.
Old Sep 22, 2003 | 12:51 PM
Nameless RB26's Avatar
Default Re: Clutch squeaks when it grabs.. (WOTTEG)
Clutchmasters are known for chirping or howling when letting out. Because they are racing clutches and they are made for a more harsh engagement.. there's nothing you can do about it except find another brand or use a stock clutch.
Don't listen to all of this BS.. it's not a bearing and it has nothing to do with your clutch slave cylinder ball or the clutch fork. If it was.. then you would hear it whenever you push the clutch in too.
Old Sep 22, 2003 | 01:07 PM
Azhten's Avatar
Default Re: Clutch squeaks when it grabs.. (Nameless EJ6)
Ok thanks guys, the sound doesn't really bother me too much, I just wanted to make sure nothing is wrong.
Old Sep 22, 2003 | 05:26 PM
Malgerus's Avatar
My ACT heavy duty pressure plate and street disc (90-91 Integra) groans when I release it, but only if I ride the clutch... is this normal?
hastingsr
Aug 23, 2008 10:08 AM
ericlee303
Sep 8, 2007 11:34 AM
lswantsvtec
Jun 25, 2007 09:37 PM
90Integra
Apr 4, 2007 03:12 PM
