No start condition for 1992 Accord
Got a no start condition with my Accord. First off every ignition component has been replaced and is working fine. Fuel system is functioning properly and has been checked. All grounds have been checked including the ground on the thermostat housing. Battery and starter is new, alternator is working fine. Checked for a spark on the Igntion Coil but no spark. The ignition coil is new too. Measured for resistance on the ignition coil wire to the ecu and found it to be ok, measured the ignition coil plug resistance to distrubitor and its ok too, but still no spark coming off the ignition coil. Anyone has a a solution?
it's most likely your ignitor inside your distributor. good luck on getting that though, those things cost more than a hundred bucks. if that's not the case, try checking your battery cables for corrosion. that's what happened to me.
auroradawnnnn
Jun 18, 2013 04:56 PM
