help gsr wont start~
Old Sep 21, 2003 | 12:20 AM
fuck honda-tech's Avatar
Default help gsr wont start~
HEy i was driving my car tonight ... and the cluster lights went out and the just the oil light and the abs light when on .. and the power of the car started to die out as well. When i slow down the car dies out and i try to start it and the engine turns over but it wont start. Also a wierd noise is coming from the engine possibly the distributor when the key it turn for 4-5 seconds then stops... my stereo, clock, horn, and siren on my alarm havent been working not sure if this corresponds to the problem >>> Any one have the slitest idea? thanks
Old Sep 21, 2003 | 12:28 AM
Slain's Avatar
check to see if your getting spark. i had a similar experience and it turned out to be my ignitor and coil. good luck
Old Sep 21, 2003 | 12:30 AM
Default Re: (Slain)
i was thinking about that cuz today i took off my valve cover and i just checked the spark plugs and one wasnt on that tight but it still wont start
Old Sep 21, 2003 | 12:52 AM
Default Re: (epsom salt)
Old Sep 21, 2003 | 12:59 AM
Slain's Avatar
i meant check to see if there is spark in the ignition system.. spark plugs would be a start. but run a ohms test on your coil to see its running properly. i'd tell you the number of ohms but let a friend borrow my helms book.. i'm sure some guys on here will chime in .good luck
Old Sep 21, 2003 | 07:25 AM
VTECorona's Avatar
Default Re: (Slain)
strange.. check fuses and see if ur battery is dead
Old Sep 21, 2003 | 10:42 AM
Default Re: (VTECorona)
any one else ?
Old Sep 21, 2003 | 10:51 AM
HeikDiesel's Avatar
I had this happen to me. My ignition went out on me. You could start the car and as soon as you let go of the key, the car would shut off. If you would turn the key back just a tad it would keep running. Does all of your instrument cluster lights come on when the key is turned to "on"?
Old Sep 21, 2003 | 10:53 AM
Full Race EG's Avatar
Default Re: (PhatAcuraIntegra)
sounds like yor battery died
Old Sep 21, 2003 | 10:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatAcuraIntegra &raquo;</TD></TR><TR><TD CLASS="quote">I had this happen to me. My ignition went out on me. You could start the car and as soon as you let go of the key, the car would shut off. If you would turn the key back just a tad it would keep running. Does all of your instrument cluster lights come on when the key is turned to "on"?</TD></TR></TABLE> yes they come on
Old Sep 21, 2003 | 11:02 AM
i just try to charge my battery but it still wont start .. the battery is not the problem.. When i trun the key the engine just makes a windy noise trying to start but it wont ... should i change the spark plugs ???
Old Sep 21, 2003 | 11:15 AM
iLLustriouS187's Avatar
it could be your alternator, it happend to me.
Old Sep 21, 2003 | 11:29 AM
Default Re: (iLLustriouS187)
what are some trouble shooting signs that an alternator would go bad ?
Old Sep 21, 2003 | 11:33 AM
yesterday the car died out when i was driving ... i unpleasantly started it a couple more times to make it home and the car wouldnt idle.. it would just die out at low rpms
Old Sep 21, 2003 | 11:48 AM
i jump started my car and it works but it seems really weak im not sure whats up...??? so its an alternator and possibly something else! I need to get to school monday !
Old Sep 21, 2003 | 05:32 PM
Powertothe240's Avatar
You might want to try checking all of the grounds on your engine to see if any are loose. My cousin's GSR had similar problems and had us scratching our heads for a weekend. Turns out, the mechanic that installed his clutch forgot to tighten the ground near the starter and that was causing all the problems.
Old Sep 21, 2003 | 06:14 PM
ToFu-DeLiVeRy's Avatar
Like Slain said check for spark from your plug wires. If the engine is cranking then there's probably a chance that the engine isnt getting spark. I had a similar experience with my friends car and i was driving it. He had some crack juice in his car and i floored it bu then when i stopped the car just died out. We were stuck on the road trying to figure out why it wouldn't start. The engine was cranking but it wasn't getting any spark. Turned out we fried the icm in the distributor so crack that sucka open and see if its busted.
tambara
16
Apr 20, 2008 01:01 PM
int1992
Nov 10, 2007 10:16 PM
bmxbikes
22
Jul 4, 2007 07:23 PM
DVS Luder
Nov 24, 2004 12:41 PM
E Swift
Sep 3, 2003 05:46 PM
