had my car dyno tuned
Old Sep 20, 2003 | 11:53 PM
egb20's Avatar
Default had my car dyno tuned
i had my crvtec tuned and im not happy. i have b20 & b16 head with 11:1 wisecos w/85mm bore crower springs and retainers crower stage 3 rc310 injectors b&m fuel presure regulator apexi vafc2 powercore header & race cat apexi n1 cat back powercore crank pully act clutch w/ fly wheel on 15" rotas. ilaid down 180.9whp @ 7600rpm & 131.6 wtq @ 6500rpm.
Old Sep 21, 2003 | 12:15 AM
Calavera's Avatar
Default Re: had my car dyno tuned (egb20)
goddamn and I thought I had it bad at 198whp.
whats your timing set at? can you post the dyno sheet? do you have a air fuel graph too by any chance?
Old Sep 21, 2003 | 12:21 AM
egb20's Avatar
Default Re: had my car dyno tuned (Calavera)
i don't have af graph
Old Sep 21, 2003 | 12:22 AM
egb20's Avatar
i don't have a sanner
Old Sep 21, 2003 | 12:33 AM
shant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb20 &raquo;</TD></TR><TR><TD CLASS="quote">i had my crvtec tuned and im not happy. </TD></TR></TABLE>
What was the base-line figure or number compared to the tuned figure or number? what dyno were you on? is the motor broken in yet? do you have cam gears? what are the settings of the cam gears? is the motor decked? and how much is the head shaved? what is the part number on the crower stage 3 cams? what intake manifold are you using? what throttle bodie and what size? I dont think you header is up to par for your motor? especialy since its 85mm 2.0L motor.
What fuel pump and what fuel pressure are you running?
Sorry for all the questions. Just trying to figure out whats going on here.
Modified by shant at 4:44 AM 9/21/2003
Old Sep 21, 2003 | 04:18 AM
TimoneX's Avatar
New User
Nice setup...more than a little like mine. What altitude you at? 63403 cams in there? If they're the 03s then you should really get your compression higher. Your dynamic compression is probably below stock with those cams. I calculated mine out to around 11.4 just above sea level w/ a static c/r of 12.8 so the drop in compression is nothing to sneeze at.
Old Sep 21, 2003 | 04:30 AM
advanracing62's Avatar
Default Re: had my car dyno tuned (TimoneX)
did you have it tuned.. or just dynoed- I know what the title says.. but I'm just making sure. I'm surprised that you're that low. I've got a stock bottom end with JUN III cams and have 190whp... I'm thinking there's something wrong somewhere in the setup-maybe the tuner?
Old Sep 21, 2003 | 06:11 AM
vtecdamian's Avatar
wow....i have a similar setup b20 84.5 mm gsr head skunk intake.sjunk 1 cams..headertech headers......hondata s200 and rc 370's....i wamde 195 whp......soon ill get a better throttlebody and and iridium plugs.......that with another 3 hrs of tunning should get me to 200......have u done a compression test???.....where does the car start making torque???....wheres vtec set at?.....even if u dont have the a/f graph...do u remember what it looked like....let us know.....
Old Sep 21, 2003 | 05:27 PM
stick's Avatar
decent #'s
what were u expecting?
what type of intake and int mani? cam gears? if so, were they adjusted?
timing? redline? fuel pressure? vtec xover?
your headers may be hurting u and could be the culprit. not to familiar with crower cams but would not use them.
Old Sep 21, 2003 | 07:40 PM
stupidfast's Avatar
Default Re: had my car dyno tuned (stick)
that sucks, I would have guessed 215whp, get a new tuner..
Old Sep 22, 2003 | 01:37 AM
egb20's Avatar
my cam gears r set at 0 they said they tuned them but i don't thank they did dis is at 22 fuel pressure @ 58 @ 3000rpms vafc is @ +12 all the way to 8500rpms vtec is set at 5500rpms stock b16 intake manifold stock air box with bottom takin out & k&n filter
Old Sep 22, 2003 | 01:54 AM
Calavera's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb20 &raquo;</TD></TR><TR><TD CLASS="quote">my cam gears r set at 0 they said they tuned them but i don't thank they did dis is at 22 fuel pressure @ 58 @ 3000rpms vafc is @ +12 all the way to 8500rpms vtec is set at 5500rpms stock b16 intake manifold stock air box with bottom takin out & k&n filter</TD></TR></TABLE>
huh?
Old Sep 22, 2003 | 02:04 AM
egb20's Avatar
Default Re: had my car dyno tuned (shant)
bass line run 174.5@7500 whp & 125.2 @6400 wtq tuned was 180.9 whp @7600 131.6 wtq @6500 but they stopped at 7600 & it was still making power. it was a tecnodyno . the motor has 3400 miles on it. they said they set the cam gears but there at 0. motor is not decked. part # is 63403. stock intake manifold stock throttle body. stock fuel pump fuel pressure set @ 58. header is ok
Old Sep 22, 2003 | 06:42 AM
B16C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stick &raquo;</TD></TR><TR><TD CLASS="quote">not to familiar with crower cams but would not use them.
that's one stupid comment. if you don't know **** about them, then why wouldn't you use them? everyone i know that used Crowers make really good power. just another mislead person.
Old Sep 22, 2003 | 07:13 AM
1bad-eg's Avatar
Definitely sounds like your tuner, bro. That seems too low for your setup.
Old Sep 22, 2003 | 11:00 AM
igotyofire's Avatar
Default Re: had my car dyno tuned (1bad-eg)
i think it is not really the tunning buy maybe the throttle body and intake manifold being stock, i mean the b16 throttle body is smaller then itr, and now u have a 2.0 not a 1.8 and still using it. also the intake manifold, my friend made about the same power with similar setup
Old Sep 22, 2003 | 02:14 PM
AllmotorJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb20 &raquo;</TD></TR><TR><TD CLASS="quote">i had my crvtec tuned and im not happy. i have b20 & b16 head with 11:1 wisecos w/85mm bore crower springs and retainers crower stage 3 rc310 injectors b&m fuel presure regulator apexi vafc2 powercore header & race cat apexi n1 cat back powercore crank pully act clutch w/ fly wheel on 15" rotas. ilaid down 180.9whp @ 7600rpm & 131.6 wtq @ 6500rpm. </TD></TR></TABLE>
I bet if you got some custom header...you will see a big increase in whp (at least 10whp) & rpm range. Also...I would not use Crower stage 3 cams. From what I heard...crower stage 3 were tested and made minimal gains over crower stage2. I am not saying Crower is bad. I just said I wouldn't use stage 3. Thats just my opinion.
Old Sep 22, 2003 | 05:11 PM
stick's Avatar
Default Re: had my car dyno tuned (B16C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C &raquo;</TD></TR><TR><TD CLASS="quote">
that's one stupid comment. if you don't know **** about them, then why wouldn't you use them? everyone i know that used Crowers make really good power. just another mislead person. </TD></TR></TABLE>
not mislead just i dont believe in crower cams and longevity. id rather have OE cams than these and ur exactly right, since i dont know **** about them, i wont use them
back to topic: looks like ur running pig rich. if ur tuner said he adjusted cams but their at zero, FP is 58, 12+ fuel on VAFC, only went to 7600rpms then i would agree and go somewhere else to tune.
tell me about ur header? what makes u think it is a good one?
Old Sep 22, 2003 | 05:19 PM
shant's Avatar
my crower stage 3 cams made 19 whp and 6tq over 99 R cams, both tuned. btw my peak hp is at 8900 rpm, you might want to spin the motor a bit higher if the power has not peaked yet.
I dont think Crower cams have anything to do with the problem, i think the intake manifold, header and tuning are areas to look.
Old Sep 22, 2003 | 07:01 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1bad-eg &raquo;</TD></TR><TR><TD CLASS="quote">Definitely sounds like your tuner, bro. That seems too low for your setup.</TD></TR></TABLE>
Old Sep 22, 2003 | 07:02 PM
desert eagle's Avatar
what kinda engine?
what kinda c\r ?
thats ****** nice.
(egb20) jermy are u gonna get ur car retuned before i come home in late oct\ early nov ? i wanna see low\mid 13s.
Old Sep 22, 2003 | 07:37 PM
GOLDBERG's Avatar
Default Re: had my car dyno tuned (B20vtec81)
change the intake manifold also..maybe a itr?
Old Sep 22, 2003 | 09:59 PM
Calavera's Avatar
Default Re: had my car dyno tuned (GOLDBERG)
your base run seems okay.
for intake manifold I'd go with a skunk2 or oem ITR one or that new AEBS one that supposedly shows some really nice gains. I'd go with a bigger tb too.. ~68mm TB's. I'd also have them port matched if I had some extra $$.
and is your apexi exhaust 2.5"?
You should AT LEAST be at 195whp and 138ish torque with that setup.
and I agree, have someone else tune it. how long did that guy spend tuning your car? looks like half an hour while he was on the phone.
Old Sep 22, 2003 | 11:17 PM
TimoneX's Avatar
New User
The Crower 63403 cams are fine cams, I've been running them for nearly 2 years. They're sick compared to the CTR cams I replaced. I'd guess you need a different header as badly as do I bro. My power hits a wall right around 200WHP. We need a group buy on comptech race headers.
Old Sep 23, 2003 | 01:25 AM
egb20's Avatar
1st dyno was at 10:18am 2nd was at 11:06am from srd and it cost 180.00
Modified by egb20 at 10:59 AM 9/23/2003
b20sedan
102
Dec 7, 2007 07:12 AM
dc r-spec
Mar 1, 2006 08:44 AM
myhatchrips
Feb 9, 2004 07:18 PM
dc4drewH
May 8, 2003 12:05 PM
fe519
Feb 5, 2003 01:47 PM
