who knows the best way to strip paint?
Old Sep 20, 2003 | 09:13 PM
GregblkEx04's Avatar
Default who knows the best way to strip paint?
i am wondering how to strip the paint off of a used urethane wingswest type-r lip i got for $20. It is silver now and it will be less to paint of i can strip it myself. Anyways if anyone can help i would be very grateful. Also does anyone know the name of the paint used for urethane? i know its different then what you would normaly use for the body paint. Thanks
Old Sep 20, 2003 | 09:45 PM
integ 1983's Avatar
I sanded mine with about 1500 grit sand paper then wen i started hitting the urethan i switched to 2000. its gonna take time
Old Sep 20, 2003 | 10:34 PM
Vtecfool's Avatar
Default Re: (integ 1983)
couldn't you use air craft?
Old Sep 21, 2003 | 03:54 AM
i tried aircraft but didn't have the proper tools, we tried just pouring it on and letting it soak in but it didn't work cause you need a high power sprayer for it. I will give the sandpaper a shot, i just figured there had to be an easier way. thanks.
Old Sep 21, 2003 | 06:13 AM
Prevail's Avatar
Default Re: (unityx00x)
Get it in an aerosol can.. although I'm not sure if it's safe for use on plastics?
And don't get it on your skin.. burns like hell!
Old Sep 21, 2003 | 10:02 AM
DownBoyDown's Avatar
Air craft stripper or any other kind of chemical should not be used on urethane or plastic. It will eat the lip up. Try using a heat gun and heat portions of the paint, and then try lifting it with a putty knife and pealing it by hand. If that doesnt work then use some 80 grit and take it down to the primer level just before you hit urethane. Next use like 150-220 grit and sand the entire lip before you primer it.
Old Sep 21, 2003 | 10:04 AM
Oh hey I forgot, be careful not to get the lip too hot! I think if you get it too hot it might start to bend and warp.
Old Sep 21, 2003 | 10:33 AM
Team's Avatar
Default Re: (DownBoyDown)
Theres 100 different ways to strip paint... they all have there pros and cons.
Old Oct 1, 2003 | 06:47 PM
i started sanding it, works well so far, just is a bitch to get in the rounded parts. Thanks.
6thgenftw
Paint and Body
12
Jun 23, 2012 06:53 AM
GoLowDrew
Paint and Body
May 16, 2010 05:21 AM
gator88
Detailing
Feb 1, 2009 01:49 PM
Mr. Bob Dobalina
Feb 17, 2006 10:58 AM
Heisdan
Jun 27, 2003 10:32 PM
