need some advice on a intake manifold
Old Sep 20, 2003 | 07:54 PM
capcon83's Avatar
Default need some advice on a intake manifold
i wanted my next mod to be an intake manifold and was wondering what you people think,
My mods
car
**2001 ITR
motor
**B18C5 (for the people that always ask dont know why but whatever)
modifications.
**Hytech header
**Hytech exhuast (with cat and resonator that came from hytech)
**Spoon Cams & Camgears. valve clearence set at (IN 0.18mm) (EX 0.20mm) thanks to Alan at A&J Racing Motorsports
**AEM cold air intake
**Apexi V-AFC controller
**FPR
to view a larger pic add a " .orig.jpg " at the end of the adress when you copy and past it to a browser
copy the shortcut on the bottom link and paste it into a internet browser to view a bigger picture
Copy this Shortcut and Paste in URL
i dont know what intake manifold is good but im deciding between these three,
JG edelbrock, AEBS Typhoon Intake Manifold.
what do you guys think?
Modified by capcon83 at 5:05 AM 9/21/2003
Modified by capcon83 at 5:11 AM 9/21/2003
Old Sep 20, 2003 | 07:57 PM
itr817's Avatar
there is no real need for a new intae manifold...but if you want one, then i would suggest AEBS's intake manifold...but your set up does not really warrant a new manifold...the ITR one is a good manifold.
Old Sep 20, 2003 | 08:02 PM
capcon83's Avatar
Default Re: (itr817)
so what you guys think my next mod should be?
valvtrain so i could raise my revlimiter?
change my AEM cold air or is that good enough?
i just want some suggestions so i have a variety on what i should do next
thnx
Old Sep 20, 2003 | 08:10 PM
Big Teggie's Avatar
Default Re: need some advice on a intake manifold (capcon83)
The Skunk2 manifold is the same thing as the ITR manifold.
capcon83's Avatar
Default Re: need some advice on a intake manifold (Big Teggie)
thanks thats out of the question now
Old Sep 20, 2003 | 08:11 PM
jond's Avatar
Default Re: (capcon83)
lightweight flywheel. lightweight wheels. shorter gears.
Old Sep 20, 2003 | 08:16 PM
Champ R's Avatar
Default Re: (jond)
Looks like you are already making some good power with your setup capcon... why not try a JDM final drive, light flywheel or suspension?
Old Sep 20, 2003 | 08:30 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capcon83 &raquo;</TD></TR><TR><TD CLASS="quote">so what you guys think my next mod should be?
thnx</TD></TR></TABLE>
Answer me this.
Why do you NEED another mod? Your car makes some seriously nice power now.
Do you track your car? drag? anything? just street?
If you have something that you feel is not right with the car, address that, and find out what mods may help to fix the problem.
If you just want to buy a mod to buy a mod, don't buy a mod.
I would not buy an IM.
I personally, with your setup, (for myself of course), would get a lightweightf lywheel and clutch, suspension, a seat, steering wheel, camber kit, and a roll bar. But that's just me. I'm pretty vehemently opposed to changing internals in my engine, seeing as 190hp and 130tq on a track is VERY fast, even without suspension, etc.
Old Sep 20, 2003 | 08:37 PM
Rob Dizzle's Avatar
i would have a custom intake manifold or buy a b16 head and get it ported
you definetly do lose power from about 7k though from lack of air most likely
or look into getting a hondata setup
lawrence @ dsr can tune hondata pretty good
you might have around 5whp from 5k up with just hondata
jg intake manifold wont make good power for a street kaa unless you are above 7krpm all the time
there are 3-4 cars about to dyno the aebs you could wait for that, or get one and try out for yourself
Old Sep 20, 2003 | 11:36 PM
Calavera's Avatar
Default Re: need some advice on a intake manifold (Bob-DC2)
Go for the AEBS and post dynosheets for everyone. they go for what, 160 bucks...thats really cheap too.
Old Sep 20, 2003 | 11:47 PM
ballsoutracecar's Avatar
I agree with Champ R, get the JDM or or even ATS final drive of 4.929.
Top speed will drop from 150 to 137 (approx) but acceleration will increase.
Old Sep 21, 2003 | 12:37 PM
AzG35's Avatar
Default Re: need some advice on a intake manifold (Calavera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">Go for the AEBS and post dynosheets for everyone. they go for what, 160 bucks...thats really cheap too. </TD></TR></TABLE>
If you do that, have it extrude honed or send it to DPR to have them port it out. It will help clean up the inside of the AEBS. It should add a decent amount of power (2-6hp) throughout your powerband.
Old Sep 21, 2003 | 01:19 PM
patdemps's Avatar
Default Re: need some advice on a intake manifold (AzSi22)
JDM Final Drive for sure.
Do you have an LSD? If not then i'd definately get one.
Clutch, Flywheel, Lighter rims are good options as well. I would keep your stock Intake Manifold.
Old Sep 21, 2003 | 04:59 PM
capcon83's Avatar
Default Re: need some advice on a intake manifold (patdemps)
Thanks for all your guys recomendation,
I have lsd and im realy not into autocross, never did it, i mostly drag race. the jdm final drive is it expensive, and costs of putting it in?
but i should go with hondata like laurence said and get a vailve train so i could set my revlimit higher cause i make power up there.
Old Sep 21, 2003 | 05:02 PM
capcon83's Avatar
Default Re: (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
Answer me this.
I personally, with your setup, (for myself of course), would get a lightweightf lywheel and clutch, suspension, a seat, steering wheel, camber kit, and a roll bar. But that's just me. I'm pretty vehemently opposed to changing internals in my engine, seeing as 190hp and 130tq on a track is VERY fast, even without suspension, etc.</TD></TR></TABLE>
Probly need another mod to help with that hump on my power band i guess people call that the aem hump.
i drag race my car.
nothing is wrong with the car.
Old Sep 21, 2003 | 05:09 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
I love the JDM final drive, I would either go with that or doing some work on the valvetrain i.e. cams, springs, retainers etc. Get it tuned again, and go have fun.
Old Sep 21, 2003 | 05:20 PM
GokuSSJ4's Avatar
i drag race my car.
nothing is wrong with the car.</TD></TR></TABLE>
if you are in to drag racing , then you can benefit with a shorter FD . like 4.7jdm or even the ATS 4.9 a nice clutch and flywheel combo would be nice .That way you shoulnt have any problems went you launch of the line . From there you can work on suspension , racing seats would be nice . If you still feel the need for more power (which is going to cost you ) then p n p and more CR would help (but thats just opening a can of worms that later on you can regret ) remember that right now your set up is very reliable so i would keep that in mind
Old Sep 21, 2003 | 06:09 PM
DarthLuder's Avatar
New User
Default Re: (Spoon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 &raquo;</TD></TR><TR><TD CLASS="quote">
if you are in to drag racing , then you can benefit with a shorter FD . like 4.7jdm or even the ATS 4.9 a nice clutch and flywheel combo would be nice .That way you shoulnt have any problems went you launch of the line . From there you can work on suspension , racing seats would be nice . If you still feel the need for more power (which is going to cost you ) then p n p and more CR would help (but thats just opening a can of worms that later on you can regret ) remember that right now your set up is very reliable so i would keep that in mind </TD></TR></TABLE>
JDM final drive goes for $399 at Jdmspec.
Old Sep 21, 2003 | 07:45 PM
capcon83's Avatar
Default Re: (ITR GURU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR GURU &raquo;</TD></TR><TR><TD CLASS="quote">
JDM final drive goes for $399 at Jdmspec. </TD></TR></TABLE>
how much do you think install should cost. i dont want anything to mess up so like how much would it be from the acura dealers?
also its $450 at jdmspecperf.com
Old Sep 21, 2003 | 07:47 PM
v-attack's Avatar
Probably more than a new transmission.
Old Sep 21, 2003 | 10:47 PM
Calavera's Avatar
Default Re: (v-attack)
dont go to the dealer!!!!!!!! I doubt they'll want to install the fd for you anyways. they can get sued if an aftermarket part they installed ***** up anything so they wont touch it.
Old Sep 22, 2003 | 07:09 AM
DarthLuder's Avatar
New User
I'm sure there are good places to get the fd install done in Cali. Its on sale, for $400
Modified by ITR GURU at 11:02 PM 9/22/2003
Old Sep 22, 2003 | 07:16 AM
GokuSSJ4's Avatar
have you consider the 4.9FD IMO is worth the extra money . I have the 4.7FD and i wish i would of spend the xtra on going with the 4.9FD .. My next tranny will have that set up , 4.9FD with a quaife LSD
Old Sep 22, 2003 | 09:04 AM
Larkin W.'s Avatar
Find someone to do it who is a friend or trustworthy H-T member.
-Larkin who had friends install his clutch/fly for dinner at a Japanese steakhouse
Old Sep 22, 2003 | 09:47 AM
iperez's Avatar
What is your 1/4 mile time and trap speed with 190+hp ??
