Should I turbo my GSR?
Old Sep 20, 2003 | 07:36 PM
eman01's Avatar
Default Should I turbo my GSR?
ive been seriously considering buying a turbo for my 98 gsr but im still a little cautious because i have never seen anyone do it before and am not quite sure what the effects would be. Could anyone tell me @ how much hp it would have and how it would fair in the 1/4? thanks for any help the u can give me
Old Sep 20, 2003 | 07:46 PM
The HamsterBall's Avatar
Default Re: Should I turbo my GSR? (eman01)
yeah man. go for it.
and there have been people that have turbo'd their GS-R's. Even people who've turbo'd their ITR's too.
just don't blow your motor =P
Old Sep 20, 2003 | 07:50 PM
eman01's Avatar
Default Re: Should I turbo my GSR? (HamsterBall)
do u know how much hp the vtec gets from a turbo? ive been askin around but no1 seems to be really sure.
by the way... what would cause it to blow my engine?
Old Sep 20, 2003 | 08:08 PM
CNSK's Avatar
Do a compression test to see what your numbers should turn out.....should be around 225-230 across. Each turbo is unique in there own way and depending on what stages your running. Just push about 8-9 psi on stock internals and go dyno your car. Thats just the best bet to know your own power.
Old Sep 20, 2003 | 08:23 PM
threatcon13's Avatar
New User
Default Re: Should I turbo my GSR? (DrMartin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrMartin &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression test to see what your numbers should turn out.....should be around 225-230 across. Each turbo is unique in there own way and depending on what stages your running. Just push about 8-9 psi on stock internals and go dyno your car. Thats just the best bet to know your own power. </TD></TR></TABLE> theres not really an average for compression numbers...as long as they are consistent all across you should be good, and as long as they are not abnormally low. Before you turbo your car I suggest ( saying all this from personal experience) you do a lot of research on turbo systems, and how they work, and how they will affect your motor. There is a good book by Corky Belle? on turbo systems. Good luck.
Old Sep 20, 2003 | 09:16 PM
itel7's Avatar
What kinda question is that,
of course!!! but you gotta swap the tranny to an ls (longer gears more room for turbo to open up) there after get dual ball bearing for that, these are two tips, good luck and follow up on it!!!!
Old Sep 20, 2003 | 10:09 PM
JunIntegra's Avatar
Default Re: (itel7)
no need for an ls tranny- gsr is fine
there is rev hard (personal fav), drag 3, max rev, full race, etc for turbo kits
about the vtec... my honda mechanic, gained 60 WHP going from his LS motor to LS/VTEC (b16 head) and topped @ 402whp.runs high 11's. hope this helps
Old Sep 20, 2003 | 10:29 PM
-iLLuZioN-B18C1's Avatar
go read up in the forced induction forum. lots of smart knowledgable people in there with 500+ whp.
Old Sep 21, 2003 | 01:14 AM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eman01 &raquo;</TD></TR><TR><TD CLASS="quote">do u know how much hp the vtec gets from a turbo? ive been askin around but no1 seems to be really sure.
by the way... what would cause it to blow my engine?</TD></TR></TABLE>
VTEC does not increase HP - turbo or not
Old Sep 21, 2003 | 02:17 AM
thrty8street's Avatar
how does vtec not increase horspower? any vtec head will make as much or more than a honda engine without a vtec head.
Old Sep 21, 2003 | 08:00 AM
JunIntegra's Avatar
Default Re: Should I turbo my GSR? (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">
VTEC does not increase HP - turbo or not</TD></TR></TABLE>
HUH?? WTF? dude what are you doing here?
Old Sep 21, 2003 | 10:38 AM
Default Re: Should I turbo my GSR? (JunIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunIntegra &raquo;</TD></TR><TR><TD CLASS="quote">
HUH?? WTF? dude what are you doing here?</TD></TR></TABLE>
maybe he's not refereing to VTEC itself. maybe he is saying that the vtec head will have better flow ect than not vtec. also, maybe he is specifically thinking about the cams and how the lobes are designed, not necesarilly VTEC.
im not sure.
Old Sep 21, 2003 | 11:35 AM
BigMikeyStyle247's Avatar
turbo that ****, just keep the boost at about 7-8 if its on a stock motor
Old Sep 22, 2003 | 08:50 AM
Default Re: Should I turbo my GSR? (BigMikeyStyle247)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMikeyStyle247 &raquo;</TD></TR><TR><TD CLASS="quote">turbo that ****, just keep the boost at about 7-8 if its on a stock motor</TD></TR></TABLE>
Dont forget to get some good tunning time too.
Old Sep 22, 2003 | 09:43 AM
Rob Dizzle's Avatar
Default Re: Should I turbo my GSR? (thrty8street)
how much money do you have?
I wouldnt do it if you are just getting by
turblows will show weakness in your engine/valvetrain
you have to be aware if you screw up something, you might need to get a new turbo or engine
turbo is cool for big power. but if are going to go turbo do it right, and to do it right is not cheap
Old Sep 22, 2003 | 12:34 PM
WOTTEG's Avatar
No, save up for down-payment on a house, or a wedding ring for your sweetie.
Old Sep 22, 2003 | 01:10 PM
quikB18B's Avatar
Default Re: Should I turbo my GSR? (WOTTEG)
Gsr is a great motor/tranny to boost. It already has the gsr tranny(great for a street car) Dont listen to the guy sayign to go with ls tranny. That myth was started in like 98 . On a typical turbo kit with basic fuel setup a gsr will make anywhere from 250-260whp, we have seen some 270's as well. The key to not blowing your **** up is to know what your doing, dont get boost happy with your boost controller, and tuning most imnportant. Turbo has huge potential and you can mix and match parts of your choice. If you are a turbo noobie then research and learn the in's and outs before blowing your $ on wortless parts .
Old Sep 22, 2003 | 01:32 PM
turbo craig's Avatar
Default Re: Should I turbo my GSR? (quikB18B)
do it!!!
Old Sep 22, 2003 | 01:46 PM
phuckinilltegie's Avatar
Default Re: Should I turbo my GSR? (turbo craig)
definately, i don't recomend a drag kit though
Old Sep 22, 2003 | 01:50 PM
Street_Kings's Avatar
I've got a boosted GS-R...No Problems Really, you wanna have a good tuner and fuel management if you want to run a lot of boost. E-mail/PM me for Complete walkthrough/w pics of how i did mine.
Old Sep 22, 2003 | 01:51 PM
Mr Type R's Avatar
i dont think you should turbo your car . Hondas are at there best all motor. If you turbo the gsr you will bairly hear VTEC, and your motor will not last as long. All motor is the way to go. Turbo All motor
Old Sep 22, 2003 | 01:52 PM
Default Re: Should I turbo my GSR? (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">
im not sure.</TD></TR></TABLE>
If this is true, then you must also say a turbo does not add HP. The Way the turbines and piping are designed to compress the air is what is responsible. How much sense does that make? it's the same thing!
Old Sep 22, 2003 | 02:27 PM
sickness's Avatar
Default Re: Should I turbo my GSR? (Mr Type R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Type R &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you should turbo your car . Hondas are at there best all motor. If you turbo the gsr you will bairly hear VTEC, and your motor will not last as long. All motor is the way to go. Turbo All motor </TD></TR></TABLE>
Old Sep 22, 2003 | 02:38 PM
intekragsr's Avatar
Default Re: Should I turbo my GSR? (ae86gsr)
You will get more intelligent responses in the forced induction forum. Start there.
BTW, get the turbo. It will not be regretted when done right.
Bob-DC2's response was one to deeply consider if going the route of the Darkside.
Old Sep 22, 2003 | 02:39 PM
eman01's Avatar
Is it true that a turbo will shorten the life of my car? i dont want to cut 50k miles off its lifespan.. im gonna need this car for a while. anyone know what the long term affects are?
