Koni yellows w/neuspeed sport springs or Apexi World Sport Dampers?
Old Sep 20, 2003 | 06:30 PM
R.S.'s Avatar
Default Koni yellows w/neuspeed sport springs or Apexi World Sport Dampers?
I can get both fo about the same price, which would be betta, my car is a daily driver (but I don't mind a very stiff ride) but i do plan to autoX sumtime.
Old Sep 21, 2003 | 06:33 AM
R.S.'s Avatar
Default Re: Koni yellows w/neuspeed sport springs or Apexi World Sport Dampers? (-R-)
bump
Old Sep 21, 2003 | 07:27 AM
thrty8street's Avatar
arent the apexi WS dampers like 2G's? thats madd money if thats true. i would just go with koni yellows with ground controls
Old Sep 21, 2003 | 07:51 AM
R.S.'s Avatar
Default Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">arent the apexi WS dampers like 2G's? thats madd money if thats true. i would just go with koni yellows with ground controls</TD></TR></TABLE> no they are about 1g but i can get em fo $750
Old Sep 21, 2003 | 02:07 PM
R.S.'s Avatar
bump
Old Sep 21, 2003 | 02:55 PM
wall of tvs's Avatar
Default Re: (-R-)
Koni Yellows with Eibach Pro Kit springs
Old Sep 21, 2003 | 05:05 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (-R-)
WS dampers brand new shouldn't cost much more than $800-$850 or so.
But you have to weigh the differences, WS dampers do not offer any damping adjustment. Konis offer limited height adjustment and infinite rebound damping adjustment.
I don't know how stiff the WS springs are.
Old Sep 21, 2003 | 06:06 PM
R.S.'s Avatar
Default Re: (PatrickGSR94)
the ws springs are stiffer then the neuspeeds that i was gona get
Old Sep 22, 2003 | 05:09 PM
R.S.'s Avatar
bump
Old Sep 24, 2003 | 04:39 AM
Alexander's Avatar
Default Re: (-R-)
why are you settling for just these two options?
I have Koni Yellows, but wish I had a full coilover to adjust the height (the height adjustment perches are uneven, not even worth trying). I don't feel like GC's because I just don't think it will "feel" right.
However, I don't think I could live without the rebound adjustment.. its just so easy, and you feel so much more in-tune with your car.
If you have the money, go for a full coilover WITH rebound/dampening adjustment.
A.
Old Sep 24, 2003 | 06:18 AM
R.S.'s Avatar
Default Re: (AVD23)
I don't have the $$$$ i was only goin to spend like $300, but i talked my self into spendin like $800, but no more then that (I'm young and poor)
Old Sep 24, 2003 | 08:10 AM
Tweakmeister's Avatar
Default Re: (-R-)
if you do get the WS then BE SURE to clean the shockbody threading periodically.
Old Sep 24, 2003 | 10:46 AM
au-gsr's Avatar
Default Re: (Tweakmeister)
i hate my koni's and ground control coilovers. in the winter they squeak and make weird noises. this is because the more you drive on them the more hte seat mounting points wear down. when they get real bad you have to replace the coilover/koni collar and the coilover sleeve. mysuggestion is if you only have about 800 to spend:
go with a set of eibach pro kit springs on either KYB agx's or Tockico 5 way adjustable struts.
the thinking behind this is simple. even if yuo just buy the koni's and springs the spring perches are gonna be just aas noisy as the coilover perches. why? because they aren't welded to the shock body. now tih the KYB and Tockico's, the spring perches are welded to the shock body. creating a solid perch that won't squeak around on you and get you all mad becasue you just dropped 800+ dollars on what was supposed to be a great suspension. i am lookin into upside down struts now. bigger inner stanchion tubes = less body roll and increased shock rigidity. sor tof looking for something like this http://www.dmshocks.com/docs/products.html i am looking at either the 40 or 50mm kits. these guys also let you choose what spring rates you get and the springs a dual progressive front and rear to assure the best ride out there. the shocks are user serviceable and have millions of ways to adjust them.
verycleanhatch
Suspension & Brakes
Oct 10, 2007 03:07 PM
chris3k
Feb 4, 2007 06:50 PM
nortel
14
Feb 18, 2004 03:54 PM
Kwisatz Haderach
Feb 21, 2003 01:51 PM
Rob Dizzle
Nov 22, 2001 07:04 PM
