header, cat, exhaust sizes
Old Sep 20, 2003 | 06:21 PM
R.S.'s Avatar
Default header, cat, exhaust sizes
ok i'm goin to be gettin a header, cat, and exhaust. I'm plannin on a GReddy 1 piece 4-2-1 header, i'm prob gona get 65mm or 60mm diameter exhaust piping, and i need a cat that will bolt up to them.
any 1 got suggestions about cat's, i've heard bad things about carsound so i don't think i want 1 of those, any recommendations?
Modified by -R- at 6:58 PM 9/21/2003
Old Sep 20, 2003 | 08:38 PM
TimoneX's Avatar
New User
Default Re: header, cat, exhaust sizes (-R-)
Carsound is the best constructed high flow cat I've had experience with. The other I've played with was a random tech cat, and it was falling apart after a single MI winter.
Old Sep 20, 2003 | 10:26 PM
riceball777's Avatar
carsound
Old Sep 20, 2003 | 10:37 PM
Brandon Chun's Avatar
Default Re: header, cat, exhaust sizes (riceball777)
I've never heard anything bad about Carsound before, I have heard bad things about RT however. I do like my carsound cat though.
Old Sep 21, 2003 | 06:32 AM
R.S.'s Avatar
Default Re: header, cat, exhaust sizes (Brandon Chun)
oh ok cuz i've heard people going through a lot of carsound cats, but if they're all good then i'll prob get one.
but wat size? I need it to bolt up to a GReddy 4-2-1 header and 65 mm exhaust piping
Old Sep 21, 2003 | 06:33 AM
KTeller8's Avatar
carsound are very good and they do have a warrenty on them
car-sound.com
or is it carsound.com ? shrugs?
Old Sep 21, 2003 | 07:26 AM
thrty8street's Avatar
you cant go wrong with carsound cat
Old Sep 21, 2003 | 07:48 AM
patdemps's Avatar
Default Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">you cant go wrong with carsound cat</TD></TR></TABLE>
Old Sep 21, 2003 | 07:53 AM
R.S.'s Avatar
Default Re: (patdemps)
but wat size
Old Sep 21, 2003 | 07:55 AM
KTeller8's Avatar
if you have a 2.5" collector, then get a 2.5" cat and 2.5" Exhaust
worry more bout the downpipe to cat connection then the cat to exhaust connection
Old Sep 21, 2003 | 07:57 AM
MikeTV
Guest
Posts: n/a
Default Re: (-R-)
I dont know who was telling you bad stuff about carsound because they are pretty much the best aftermarket high flow cat that you can get
Old Sep 21, 2003 | 10:32 AM
R.S.'s Avatar
Default Re: (KTeller8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">if you have a 2.5" collector, then get a 2.5" cat and 2.5" Exhaust
worry more bout the downpipe to cat connection then the cat to exhaust connection</TD></TR></TABLE> i wana know about the header to cat to exhaust connections, any 1 know how big the GReddy header is where it connects to the cat?
if i buy a GReddy 1 piece 4-2-1 header, 2.5" carsound cat, and 65mm or 60mm exhaust will they all connect up or will i need to buy sum otha stuff so that they will connect?
Modified by -R- at 6:57 PM 9/21/2003
Old Sep 21, 2003 | 06:03 PM
R.S.'s Avatar
Default Re: header, cat, exhaust sizes (TimoneX)
bump
Old Sep 21, 2003 | 08:06 PM
KTeller8's Avatar
Default Re: (-R-)
take it to a muffler shop and they will get it all done for you..
it wont line and bolt up 100% perfect. but will be damm close
Old Sep 22, 2003 | 05:07 PM
R.S.'s Avatar
that's the thing i don't wana do
fo 2 resons maybe mo but i can only think of 2 fo now:
1.I like to do every thing i posibly can my self
2.Every place arround here is ****, and i espesially don't trust shops arround here
if i was going to bring it to a muffler shop i would get a custom 2.5" stainless steel mandrel bent exhaust piping from here: http://www.accordinglydone.com/store/catalog/ and have them weld the hangers and **** on...
but any ways i wana learn how to do this my self
Old Sep 22, 2003 | 08:47 PM
KTeller8's Avatar
Default Re: (-R-)
well then get a welder and order that piping kit.. and go to work
its not that hard.. just takes some time and its not that expensive of an item to try on... plus its good stuff
Old Sep 22, 2003 | 08:53 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KTeller8 &raquo;</TD></TR><TR><TD CLASS="quote">plus its good stuff </TD></TR></TABLE>
Haha - I'm not sure he's aware of your "experience" with the product.
Old Sep 22, 2003 | 09:58 PM
KTeller8's Avatar
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Haha - I'm not sure he's aware of your "experience" with the product. </TD></TR></TABLE>
Shrugs ive tested an item or two yeah
maybe i used jedi mind trick??
Old Sep 23, 2003 | 01:53 PM
ggangtong81's Avatar
how about ractive high flow CC?? are they good??
Old Sep 23, 2003 | 03:00 PM
TimoneX's Avatar
New User
Default Re: (ggangtong81)
I'm unaware of anything labeled ractive that's any good. Perhaps there are exceptions however.
Old Sep 24, 2003 | 06:05 PM
R.S.'s Avatar
wat if i got:
RANDOM TECHNOLOGY: HI-FLOW CAT for an INTEGRA 94-95 GSR
RANDOM TECHNOLOGY: HI-FLOW CAT INSTALLATION KIT for 94-95 GSR
GREDDY HEADER for an INTEGRA 94-99 GSR (4-2-1,1PC),
RS-R GT2 exhaust system (60mm)
would they all bolt up with out having to weld any thin or add any thin else????
Old Sep 24, 2003 | 10:01 PM
Padawan's Avatar
Darth ModerVader
Default Re: (-R-)
All of the flow numbers I've seen indicate that Carsound is your best choice in terms of a high-flow cat., and there are companies that can provide you with a Carsound that will bolt-up directly to your application.
Old Sep 25, 2003 | 01:11 PM
KTeller8's Avatar
Car-Sound.com
also Carsound are Carp ok and EPA approved! Comes with Warrenty papers too~
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">All of the flow numbers I've seen indicate that Carsound is your best choice in terms of a high-flow cat., and there are companies that can provide you with a Carsound that will bolt-up directly to your application. </TD></TR></TABLE>
Old Sep 25, 2003 | 04:06 PM
R.S.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">All of the flow numbers I've seen indicate that Carsound is your best choice in terms of a high-flow cat., and there are companies that can provide you with a Carsound that will bolt-up directly to your application. </TD></TR></TABLE> But wat companies, any links??
Old Sep 25, 2003 | 04:18 PM
Padawan's Avatar
Darth ModerVader
Default Re: (-R-)
I always suggest SMSP. He built my Carsound, and the welds, fit, etc. were top-shelf.
