New best time/mph
I finally achieved my goal at home. I've run a 13.77 @99.6 at a near sea level track with my old setup, but the track in my home city is 3075 feet above sea level, so it makes running faster times a challenge. My previous best with my old setup was a 14.08 @97.5 with 50 degree temps. My new best time is 13.82 @98.2 with a 60' or 1.95 on 22x8x13 M&H Slicks. This is about a 13.3 @102 (corrected) or so at sea level. I also hit a few 99mph as well, I'd like to break 100mph, maybe when it cools down, its still fairly warm 80-90 degrees. The car is a 99 Si, 2530lbs with driver. Poor man's type-R - 185hp/135torque NA. Here are some of my timeslip numbers.
R/T .647
60' 2.000
1/8 8.889
MPH 78.33
1/4 13.893
MPH 99.38
R/T .757
60' 1.957
1/8 8.840
MPH 78.20
1/4 13.872
MPH 95.41 ??
R/T .270 (whoops)
60' 1.954
1/8 8.821
MPH 78.64
1/4 13.82
MPH 98.27
Hopefully with suspension tuning I can get it down to a 13.6-13.7 range, the front wheels are unloading pretty hard on launch, need some stiffer springs in the rear.
R/T .647
60' 2.000
1/8 8.889
MPH 78.33
1/4 13.893
MPH 99.38
R/T .757
60' 1.957
1/8 8.840
MPH 78.20
1/4 13.872
MPH 95.41 ??
R/T .270 (whoops)
60' 1.954
1/8 8.821
MPH 78.64
1/4 13.82
MPH 98.27
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ispkarl »</TD></TR><TR><TD CLASS="quote">nice
slicks??</TD></TR></TABLE>
Read the post again
Good run!
Read the post again
Good run!
Thanks. Here is the complete setup by the way:
B18C1 block, 81.5mm JE pistons, 12:1 CR, stock rods (arp rod bolts), balanced crank
B16A head, Mild P&P, ITR valve springs, Portflow Ti retainers, milled .013
CTR cams
AEBS Intake Manifold
JG 64mm TB
Short Ram Intake w/ custom IceBox
DC JDM 4-1 Header
B&M FPR
APEXi N1
APEXi VAFC
Converted to OBD1, P28 Kenji Spec
Modified by AzSi22 at 10:14 PM 9/20/2003
CTR cams
JG 64mm TB
DC JDM 4-1 Header
B&M FPR
APEXi N1
APEXi VAFC
Wow man really nice times....last winter i was at 14.3 with street tires...hopefully this witner i can get a hold of some slicks and finally get my header and tune da beast so i can be at your times....Hopefully ..hey do you know what the elevation is for Firebird?
Latz
Latz
I believe Firebird is close to 1000-1100 ft. Its usually about 3-4 tenths faster than the track here because of the elevation. I am going to try to make a trip out there and see if I can get into the low 13s.
very impressive driving skills, i'm running more power than you and still cant break into the 13's and i have bfg drag radials.. my trap speed keeps getting lower and lower (one time i ran 14.5@93mph with a 2.2 60'ft) i dont know whats going on with my car, i ran 14.2 with just 180whp =o( i dont know but after the dyno my car hasnt been running the same although it makes more power than before =o(
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Holly35 »</TD></TR><TR><TD CLASS="quote">Impressive times ....lol @ the .270 R/T....I had a .198 first time down the track
Yeah, I kinda jumped the gun. I was racing 11 and 12 second V8's all night, so I needed all the help I could get.
I usually go anywhere between .500-.650. My best of that night was .507
</TD></TR></TABLE>Yeah, I kinda jumped the gun. I was racing 11 and 12 second V8's all night, so I needed all the help I could get.
V-SPEC 1
Nov 23, 2004 04:37 PM
Nextelbuddy
Jun 19, 2004 09:32 PM
el arbi
Apr 29, 2003 07:19 AM
