What harness do I need for an H22 in my 92 CX???
yes, i searched, found a bunch of useless stuff. i have an obd1 P13 ecu with the motor, and it has one empty plug on it when i plug it in. do i need an obd1 P72?? also, the vtec will not engage, so it just falls on its face at like 6k rpm and will not rev higher (i am guessing the secondary intake runners are not opening up). If anyone has any info, please let me know, i am having serious trouble with this car!
thanks
thanks
without being able to cehck the engine lights you are pretty screwed until you fix the wiring problems.
who rewired your harness to fit the h22a? i would ahve them find the problems since either the harness has problems or plugs are not going to the right sensors...or there is a short in the harness or at a plug.
thats what i was thinking. its actually my friend's car, but im just trying to help sort it out. the moron we bought it from started cutting wires on the harness in the engine bay trying to fix the 02 sensor, and when he did that, he said he saw sparks, so.....who know. but the harness is hacked all to ****, and i dont think the ecu is hooked up right. what ecu are you supposed to use with this thing? the p13 or a dohc vtec P72??? when we plug the p13 in, the car runs like ****, and dies when you push the clutch in. also, there is one empty plug on the P13 when we plug the EH2 harness into it. any more ideas anyone?!?!?
1dopesi
Sep 14, 2007 07:25 PM
