can anyone tell me what code # 3 means...
i doing a code diagnose on my 1999 civic si ,, is not starting properly ... so i did a diagnose via check engine light and .. it flashes 3 shor ones pause for about 2 sec and it repeats itslef over and over again ....
anyone know what this code means..
thanks
thanks
i was boosting 11psi without check valves....the car shuted down and now it starts but like if only 2 plugs were firing and is just dumping fuel ...cuase the plugs are wet /... as far as compression is all good .... no blown motor thank god.....
also what is code #30 ??
thanks
thanks
You sure it was a code 30 ? The accord, odessey and prelude only have a code 30 which is
Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
defective circuit or unplugged / defective sensor
