how much is cost to put in cams?
Old Aug 23, 2001 | 01:56 AM
Anthony K's Avatar
New User
Default how much is cost to put in cams?
Do any of you guys know how much a mechanic would charge to put in cams? How many hours does it take?
Old Aug 23, 2001 | 07:46 AM
Muad'Dib's Avatar
Corr Performance Pilot
Default Re: how much is cost to put in cams? (GS-R916)
I'll put this in the Teg forum.
Old Aug 23, 2001 | 07:47 AM
LRAO's Avatar
In So Cal labor for cam install is about $75 to $100.
Loc
Old Aug 23, 2001 | 08:55 AM
dustin's Avatar
Default Re: how much is cost to put in cams? (LRAO)
It is really easy though, so if you wanted to do it yourself many people here on H-T would be happy to explain the procedure.
Dustin
Old Aug 23, 2001 | 09:51 AM
C-speed's Avatar
Default Re: how much is cost to put in cams? (dustin)
If you want to do it yourself, check here:
http://www.c-speedracing.com/howto.html
Old Aug 23, 2001 | 10:12 AM
H23 Power's Avatar
Default Re: how much is cost to put in cams? (G3-TEG)
how much harder is it to change the valve springs and retainers while changing the cams?
Old Aug 23, 2001 | 10:17 AM
C-speed's Avatar
Default Re: how much is cost to put in cams? (01GSR)
A lot harder... your looking at an addition 1.5 hours of work, plus if you don't want to remove the head, you need a special tool (air compressor attachment) to pressurize the cylinder. A conventional VTEC valve spring compressor will not work as well.
Check here, you can see how its done withthe head OFF the car. Imagine doing this with it on the car:
http://www.c-speedracing.com/howto/nabuild/nabuild.html
Old Aug 23, 2001 | 10:28 AM
H23 Power's Avatar
looks like it would be worth having someone do this for me...
how much labor would be involved in getting this done?
Old Aug 23, 2001 | 10:56 AM
Go Mifune's Avatar
New User
i just paid:
$350 r and r the head
$200 lap and install new valves (ie put everything back together)
this is more stuff than you're asking about but pulling the head is not cheap.
Old Aug 23, 2001 | 11:01 AM
H23 Power's Avatar
Default Re: how much is cost to put in cams? (Go Mifune)
can most shops change the valve springs/retainers without pulling the head though? that would probably make it a lot cheaper
psegs80
Oct 31, 2009 11:25 AM
WiLLMaTiX
Aug 9, 2004 08:17 PM
guymosiris
12
Aug 20, 2003 01:51 PM
Etylorcen
Sep 4, 2001 03:16 PM
