how well do the moroso and z10 engineering traction bars work?
are they streetable? and does it lower the 60ft and quarter mile times considerably? thanks
Z10 Is the Shiznt..!!!!
Good Quality stuff...when they have stuff in stock that is
There front member is compleatly streetable also
some real data:
http://forums.clubsi.com/ubb/Forum37/HTML/000385.html
most everyone who can adjust them properly (very, VERY easy to do) has excellent results.
The concept is similar, but quite different in practice. The radius rods we produce are fully adjustable, and as a result they allow one to adjust control arm preload, and as a result adding postive caster, something that makes most any fwd car handle a bit better. Also as the connections are all solid (rod ends/heim joints) you get no slop from the stock bushings (a lot in fact... )
Also our crossmembers are tubular, mounted farther forwards than factory members freeing up space.
NonovUrbizniz
May 20, 2003 09:25 PM
