all motor buildup piston question
Old Sep 20, 2003 | 12:35 AM
toooslow's Avatar
Default all motor buildup piston question
what do you think, Pr3 pistons or the ctr pistons for my b18c n/a buildup? I will be running on 91 octane and was thinking of what would be more suitable, i know lots of people use the ctr's but the pr3s also raise the compresion to a decent amout also.
Modified by whiteinteg95 at 7:02 AM 9/23/2003
Old Sep 22, 2003 | 10:03 PM
toooslow's Avatar
Default Re: all motor buildup piston question (whiteinteg95)
anybody?
Old Sep 22, 2003 | 10:12 PM
1fasthb's Avatar
just go ctr you should be ok on 91octane
Old Sep 22, 2003 | 10:19 PM
99-DC2's Avatar
if you want to be conservative get the JDM P30 pistons... it will yield a higher compression ratio than the PR3 but lower than CTR
Old Sep 22, 2003 | 11:29 PM
-KangaRod-'s Avatar
I'd personally go with CTR overbore, but make sure you have a hondata and know what you are doing!
Old Sep 23, 2003 | 10:18 AM
toooslow's Avatar
would the ctr overbored pistons yield a lower compression ratio or is it the same as a standard bore?
Old Sep 23, 2003 | 10:40 AM
1fasthb's Avatar
Default Re: (whiteinteg95)
it would be a little higher than standard bore, not much tho
Old Sep 23, 2003 | 02:42 PM
ScottFern's Avatar
Default Re: (1fasthb)
I thought CTRs in a b18c1 with cams causes a valve/piston clearance issue......I wanted to go with CTRs, but wasn't sure if my sk2 stage 2s would cause this issue...
If he isn't planning on ever doing cams, ignore this
Old Sep 23, 2003 | 03:17 PM
WAFFLES's Avatar
Default Re: (ScottFern)
JDM P30s or JDM ITR
Old Sep 23, 2003 | 06:49 PM
Aquafina's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fasthb &raquo;</TD></TR><TR><TD CLASS="quote">it would be a little higher than standard bore, not much tho</TD></TR></TABLE>Larger bore doesn't increase the compression ratio.
I'd go with something that you could tune yourself with a VAFC unless you have money set aside to pay someone to tune it.
Old Sep 23, 2003 | 07:15 PM
1fasthb's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Larger bore doesn't increase the compression ratio.
.</TD></TR></TABLE>
oh really maybe you should research this
Old Sep 23, 2003 | 08:02 PM
toooslow's Avatar
thats why i have you wonderful experienced people that could help me
could either the type r pistons be able to handle the high compression and something such as a 75 shot of nitrous well?
Rediness_code
30
Apr 29, 2008 04:41 PM
lamboextreme
Nov 26, 2006 10:54 AM
00BlackDc2
Feb 22, 2004 12:13 AM
toohott4handlin
Jan 19, 2004 05:21 PM
10seconds
Jul 3, 2002 12:22 AM
