Swap done but here the PROBLEM
Old Aug 22, 2001 | 10:26 PM
B16Vtec's Avatar
New User
Default Swap done but here the PROBLEM
Just finish my swap B16a2 in a 92CX everything fine. Now here is the problem dam thing be overheating. I'm using the radiator from the 99SI but the fan won't come on I then slice up the wire and attached it to the battery and the fan work fine. I let the fan run awhile still the car temp. won't come down. The motor is under 25k miles everything check out fine. Can someone tell what to do?
Old Aug 23, 2001 | 05:30 AM
mafioso102's Avatar
New User
Default Re: Swap done but here the PROBLEM (B16Vtec)
does the ecu light come on, if so you can check that. It sounds like either the temp sensor, or perhaps the switch that engages your fan.
Old Aug 23, 2001 | 07:05 AM
98EX's Avatar
New User
Well, if the fan is running and still getting hot, it might be the water pump, sheck that ou, if you didn't change it when you did your swap, I recommend that.
Old Aug 23, 2001 | 09:34 AM
maxim's Avatar
Default Re: Swap done but here the PROBLEM (98EX)
also check the thermostat
jeezyskillz
Nov 3, 2006 06:20 AM
Ls_dx
16
Jun 12, 2006 08:40 AM
beerex
Apr 7, 2006 10:16 PM
celica26
Dec 29, 2004 08:40 PM
lsvtec101
Mar 27, 2003 06:20 AM
