What about this?
Old Sep 19, 2003 | 09:43 PM
rusted_eyes's Avatar
Default What about this?
Look at my signature for my current set-up. I am planning on getting skunk2 stage I cams, ITR valve springs, skunk2 programmed ecu, VAFC II, and ??? what else should I get and what do you think I might put down at the wheels, and 1/4 time. Thanks for your help and info.
Old Sep 20, 2003 | 09:41 AM
Default Re: What about this? (RdCivicSi)
any help with my set-up.
Old Sep 20, 2003 | 11:01 AM
Padawan's Avatar
Darth ModerVader
I would invest in a better header and a high-flow cat. before the cams and valvesprings. And if you're going to go through the expense of purchasing a Skunk 2 ECU and a VAFC II, you might as well go with Hondata instead. If you're dead-set on getting the cams too, don't forget a set of adjustable cam pulleys.
Old Sep 20, 2003 | 12:57 PM
Default Re: What about this? (Padawan)
thanks man I will definately look into those things.
Old Sep 20, 2003 | 01:00 PM
allmtr's Avatar
sounds like a good plan. thin out the head gasket to raise the CR.
dc4teg95
Jan 24, 2007 02:36 PM
VTECcnIT
Oct 29, 2005 04:48 PM
The Poopsmith
May 15, 2003 10:32 AM
ActiveAero
Dec 27, 2002 10:53 AM
