towing capacity of an LS integra? What have you towed?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EK9 »</TD></TR><TR><TD CLASS="quote">Hello,
I was wondering what the towing capacity of an LS integra is.
What have you guys towed with your cars? </TD></TR></TABLE>
i use a truck for towing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain »</TD></TR><TR><TD CLASS="quote">i cant imagine too much. towing around a couple of friends makes my car feel like its running on 3 cylinders.</TD></TR></TABLE>
hahaha thats what im saying!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mt3c »</TD></TR><TR><TD CLASS="quote">i've seen crx's with small boats. check in the owners manual if you haven't done so already. </TD></TR></TABLE>
I dont own an integra, or else i'd do that.
Thanks though, i've seen CRX's pulling Tire trailers and what not.
I dont own a truck so i guess thats of no help.
I dont want to tow a 5th wheel. I just want to know the towing capacity of the integra.
check your manual for the specifics for your certain car. in my owners manual, tow capcity is 1000 lbs. And tongue load is 100 lbs, whatever that is.
edit: owners manual for 1994 integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mt3c »</TD></TR><TR><TD CLASS="quote">check your manual for the specifics for your certain car. in my owners manual, tow capcity is 1000 lbs. And tongue load is 100 lbs, whatever that is.
edit: owners manual for 1994 integra</TD></TR></TABLE>
That means you can pull a maximum of 100 lbs. Tongue load is the weight that be put on your integra. Which will only be 100 lbs. So if you get some kind of light trailor that has most of its weight on the trailor axle it should be fine although I highly recommend not to tow with a honda. Most vehicles can tow stuff, but you will stress the **** out of your gears. If you want tow, get a truck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vivid02 »</TD></TR><TR><TD CLASS="quote">You can tow a yacht. </TD></TR></TABLE>
smoke .
smoke .
quicknadc2
May 19, 2007 11:01 PM
civic_crazy
Jul 27, 2004 10:06 PM
