spring length of neuspeed race?
I have a pair of front neuspeed race springs (570lb spring rate), I want to use them in the rear, will they fit? and are the rear springs longer or shorter? I would put them in the rear if they sat higher, but if its too low, I dont want to use them at all... I currently have gc's spring rates are 350f/250 rear.
thanks
thanks
i suppose you could make them fit if you use the perch from your front struts... but why?... it would be totally jacked up and probably sit alot higher... you can buy springs from gc in sets of 2 if you want stiffer springs in back
Yeah they will fit in the rear I dont know how well they sit but they do fit.
The rear shocks are shorter than the front shocks.
I think with that kind of spring rate and then putting the longer spring in back I would guess that your ride height would be basically like stock and that it would be bouncy as hell.
KillaB-
Suspension & Brakes
Jan 28, 2005 09:12 PM
snowboarderguy44
38
Nov 20, 2003 02:41 PM
VTEConly
35
Jul 22, 2003 08:49 AM
