crank senser
Old Sep 19, 2003 | 06:47 PM
martha's Avatar
Default crank senser
OK in the process of swapping a jdm h22a into my 97 lude and realized that is doesnt have a crank senser. Has anyone run into this before? After some searching I read that you can leave out the crank senser and use the jdm distibutor. How does this work anyone have a quick schematic to make this easier.
or can you swap out the timing belt gear that the senser uses?
Old Sep 19, 2003 | 09:29 PM
satan_srv's Avatar
Default Re: crank senser (martha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martha &raquo;</TD></TR><TR><TD CLASS="quote">OK in the process of swapping a jdm h22a into my 97 lude and realized that is doesnt have a crank senser. Has anyone run into this before? After some searching I read that you can leave out the crank senser and use the jdm distibutor. How does this work anyone have a quick schematic to make this easier.
or can you swap out the timing belt gear that the senser uses?</TD></TR></TABLE>
You have to put on an OBDII Oil Pump, it has the spot where you attach the Crank Position Sensor (CKP).
The CKP is item 21 that attaches to the OBDII oil pump (3) on those two castings right around the crankshaft hole.
http://www.slhondaparts.com/br...=true
Don Jefe
Apr 18, 2009 02:37 PM
wheelmaneg6
Oct 16, 2006 06:16 AM
Incubus05
Aug 2, 2005 03:51 PM
NobodysHero
May 1, 2004 11:32 AM
