building ls/vtec ....how much power is this good for?
B18B
CTR pistons
oem head gasket
B16 head.....mildly port polished
CTR cams
Toda header
I know.....I hate these type of questions too
I'm just curious
CTR pistons
oem head gasket
CTR cams
Toda header
I'm just curious
it is a good setup, each part matches eachother like the compression and the cams and the p&p'd head.. i wouldnet be suprised if it layed down 190HP and 140 TQ, depending on if you have a hondata or not...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah »</TD></TR><TR><TD CLASS="quote"> depending on if you have a hondata or not...</TD></TR></TABLE>
I've been noticing that Hondata is pretty key nowadays. I'm actually disgusted by what it can do. I can't wait untill I get one..
the reason that ls/vtecs kill b18c1's and c'5s most of the time is b/c of where their peak TQ comes in, it comes in at a lower RPM than the c1 & c5, so its more in the optimal RPM when you shift
dono what that has to do with anything but thought id share.
i made 204whp with that setup and a vafc on 91 octane. however i did have itr cams. you should make slightly more
92integraVTECgsr
May 2, 2008 11:32 PM
