HEADER GASKET PROBLEM
Old Sep 19, 2003 | 02:42 PM
halfNhalf-83's Avatar
Default HEADER GASKET PROBLEM
ok guys hope u can help with this one. I had recently purchased a chikara header for my honda accord. The problem is, is that i have blown the mid-flange gasket 3 times in the past month...and quite frankly it is getting ridiculous and costly!! i cant seem to figure out what the problem is....i have tightened and re-tightened the 3 bolts and this most recent time even used lock-tight on the bolts....and i deas what could be causing this problem.....??any help or thoughts would be great
Old Sep 19, 2003 | 03:36 PM
iam7head's Avatar
Default Re: HEADER GASKET PROBLEM (SMseagren83)
is your car lowered?
i think i bump(didnt bent the pipe , knock on e-wood) it when i go into parking, that poor thing got knock out of line.
i have it welded to one piece
Old Sep 19, 2003 | 04:18 PM
jingjing's Avatar
Default Re: HEADER GASKET PROBLEM (iam7head)
i've had the same problem with my kamikaze header. mine would blow about every 3 months. kamikaze makes a copper gasket that works good. i used longer bolts, 2 nuts for each bolt and some high temp loctite to hold it down, hopefully it will hold long enough till i get my h22 in.
Old Sep 19, 2003 | 05:37 PM
6second's Avatar
Default Re: HEADER GASKET PROBLEM (jingjing)
Hi guy I really need your help I hit my header while driving and the check light turn on I just wanna know what I have to do?
Old Sep 19, 2003 | 08:21 PM
smokin rubber's Avatar
are you tourqing the bolts in the proper sequence, inside out?
Old Sep 19, 2003 | 09:37 PM
fizzbob7's Avatar
Default Re: (smokin rubber)
a difference in headers is qualty of welds and quality of flanges.....i had a DC upper and pacesetter lower (all that was offered) on an 86 teg motor in a crx that i just welded the two together....never leaked again after that...but make sure it's not warped and that everything is fitting flush/even....a copper gasket would also be an option
Speedy5966
Nov 12, 2017 01:26 PM
fubuallstar
Jun 12, 2008 03:41 PM
VTecLude1994
Jun 27, 2005 10:04 AM
Paluce
May 26, 2005 02:25 PM
