How to take off my front bumper. 89 crx
Here's a breakdown (also on my website, I think)...
There's a bolt underneath each of the side marker lenses (the ones beside the headlights) - pull out the lenses and you'll see the bolts. There's three of the same style bolts in the center area of the bumper, half-underneath the radiator support T-shaped thing. I unbolted that rad support thing to get them out, which is easy to do - just remove the four bolts on the top that are visible, then remove the large bolt holding the license plate to the bumper (this HAS to be removed). There's also an assortment of bolts underneath the bumper, going up into the crossmember. Just unbolt those too.
Finally, you remove the turn signals from the bumper (it's easy, two screws each) and there's also two screws on each side of the bumper on the inside of the wheelwell. Just take those out, and from there your bumper should pop off.
HTH! Good luck... remember that if bolts get frozen you can always convince them to release with vice grips. I replaced all my bolts since they were all f*cked completely.
dman81
Jan 7, 2014 05:51 AM
racerxfactor
Mar 12, 2007 05:08 AM
CHRIS 1.8
12
Apr 27, 2003 07:43 PM
