Car studders some in first gear when I start to drive...help
Every now and then when I start the car and drive it could, in first gear, right after i start, it will jerk some like it wants to die, and then i give a little gas and its ok again, or, ill hold the clutch a rev through it and its fine...it it just an issue with the car not being warm, or could it be a fule clog or something somewhere? it does not do it after Ive been driving...so im assuming that the fuel hasnt fully gone through the line and that causes the hessitation, but better safe then sorry. Thanks for anything....
sounds like maby your fast idle valve is not opening... it the one right under your throttle body... make sure the water lines are properly connnected... its easy to replace when its cool... good luck,tom
what about when your motor reves up and down when idling? It does this sometimes with it's cold or hot... Lets say it's jumped to 1500 rpm then 1000 then 1500 then 1000. Any clue what could be the problem? I thought it went away but it's coming back to haunt me.
If you are having driveability issues check all of the maintenance items- plugs, cap, rotor, etc. Tune up the motor and see how things run. Then if it still has probs you have eliminated all of the obvious. hth
car reving up and down in idle.. yeah i had the same problem. i just posted my story and solution for an irratic idle yesterday. anyways, turned out to be my distributor. anyways, i agree, go get a tune up.
White92eg
Oct 9, 2010 01:48 PM
Si_eg6
18
Jan 22, 2009 06:04 PM
arielb1
Jun 4, 2005 02:30 PM
ironchef25
Dec 6, 2004 06:46 AM
... mine did this... i dont think its a big deal
