has anyone put an si differential into a zc tranny???
i need to do this because my d15b doesn't have holes for the half shaft so i want to do this so i can run stock crx axles, can this be done, im not changing the casing just the diff, any help would be great! thanks H-T!!!
i kinda did this...i put a quaife LSD for a civic si into my ZC/Si hybrid trans. the ZC tranny case is the exact same as the si case, so you should be fine.
