AC condenser fan and compressor doesnt start!!!
Old Sep 19, 2003 | 12:23 PM
freddy_hung's Avatar
Default AC condenser fan and compressor doesnt start!!!
the AC condenser fan and the compressor clutch in my 92 eg civic are not activating when i turn the AC switch on... the idle goes up and everything.. i ´ve checked if the system is low on R12 but is OK.... i dont think BOTH relays (fan and clutch) are bad.... what could be wrong?????
Old Sep 19, 2003 | 12:25 PM
(teh)H2OUUP2's Avatar
Default Re: AC condenser fan and compressor doesnt start!!! (freddy_hung)
maybe there isn't enough pressure to activate the pressure switch or it could just be a bad pressure switch. Try jumping the wires at the pressure switch to see if the fan and the clutch come on.
Old Sep 19, 2003 | 12:28 PM
Default Re: AC condenser fan and compressor doesnt start!!! (JDMSir-G)
i jumped the pressure switch wires and nothing happens!!!! HELP!!!!!!!!!!!!
Old Sep 19, 2003 | 12:46 PM
rus's Avatar
rus
Did you check the fuses? The compressor wouldn't start if the fan doesn't. My similar problem was fixed by replacing a seized fan motor.
Rus
Old Sep 19, 2003 | 01:07 PM
Default Re: AC condenser fan and compressor doesnt start!!! (rus)
there´s a 20A fuse labeled "condenser fan" i´ve checked it and is ok.... but about the condenser fan failure theory... let me check... i´ve replaced it about a year ago.. so is not THAT old..... the relays dont even make that "ticking" noise...
Old Sep 19, 2003 | 01:15 PM
rus's Avatar
rus
I believe if your low-side system pressure is low, the compressor wouldn't start.
I assume it's a recent problem, so fan/fuse would seem to be the most likely point of failure. Do you hear the compressor clutch engaging at all when you turn on the A/C?
Rus
Old Sep 19, 2003 | 01:24 PM
fred92htch's Avatar
I had this problem right after my swap. The plug for the harness right behind the driver side headlight was not plugged in all the way. Glad it was easy (and cheap).
Old Sep 19, 2003 | 01:48 PM
Default Re: AC condenser fan and compressor doesnt start!!! (fred97gle)
nop.. the compressor clutch doesnt engage.... and i jumped the low pressure switch and nothing happens... the failure was like: in the morning everything was fine, 3 hours later, when i restarted the car.. the ac compressor and condenser fan were dead
Old Sep 19, 2003 | 04:24 PM
hello!!! hello guys!!! i expected more of this forum....
Old Sep 19, 2003 | 05:19 PM
FMIDRC Racer's Avatar
first off if the idle goes up then you can rule out pressure switches being bad. check for pin outs on your manual a/c comtrols. alos check for ecu pin out and make sure that everything is ok there.
Old Sep 20, 2003 | 02:01 PM
Default Re: AC condenser fan and compressor doesnt start!!! (FMIDRC Racer)
mmm that makes a lot of sense... or maybe the ground wires for the clutch/fan relay.... thanxs anyway!!!
Old Sep 21, 2003 | 07:32 AM
Ok , i´ve checked the black/red cable from the A15 ecu terminal trough the 2nd 8 conector pin (behind the right headlight) i found a faulty wire (blk/red).. i removed the conector.. cleaned the pins... repaired the bent wire and AC again!!!!!!!
geribair
Jun 7, 2014 11:18 AM
Frozen E
85
Apr 4, 2012 02:24 AM
Bartman201
Aug 25, 2010 08:47 AM
itsalmostfrieday
Mar 31, 2007 06:58 PM
emissionsux
Jul 7, 2005 09:43 AM
